Home > Maintenance & Mods (L405) > Alternative to L405 gear selector |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 236 |
https://landrover.lakeridgeparts.com/a/Lan...22565.html
1st Jul 2023 4:14pm |
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 202 |
Does the American market use the shift lever on the L405 ?
1st Jul 2023 4:37pm |
Just had a quick look through the complete ccf files with my gap g3 iid Bt tool and can’t see anything that would need to be changed in order for a stick shift to be enabled ? So hopefully would be a straight plug and play Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
1st Jul 2023 4:42pm |
Salsbury Member Since: 19 Jun 2022 Location: Alberta Posts: 104 |
Hello from Canadia! Nope they all have the washing machine dials to the best of my knowledge. |
1st Jul 2023 5:18pm |
Hey Bora - this J-turn showmanship scores rather high on the spectacle-o-meter, what with it taking a tumble more than a gymnast at the Olympics. But in terms of actual effectiveness? It's down there with a chocolate fireman, I'm afraid.
1st Jul 2023 6:31pm |
JDGeorgia Member Since: 11 Oct 2023 Location: Atlanta GA Posts: 158 |
13th Oct 2023 2:10pm |
The L405 uses a 12 pin connector but only 7 are used. Electrically it wouldn't/shouldn't be an issue, the biggest problem I can see is that the L494 mounting frame is angled, meaning that the trim filler wouldn't sit flat in the L405 mounting frame. Next time we have a L494 trade-in I'll do a bit of side-by-side investigation, I've a feeling the CAN address structure means that if it can be electrically & mechanically fitted, the donor would at least need to be from the same MY for it to be recognised on the Powertrain CAN. |
13th Oct 2023 5:31pm |
I would LOVE to do this...
20th Oct 2023 12:00am |
OK Boys... this could be happening, it may take a year to gather all the bits/pieces and find a weekend when the wife is out of town and not wondering why I am taking apart a perfectly good truck... That being said - this is out of a 2014 L494 and mine is a 2016 L405... If Phoenix is right - that could be an issue. If anyone has a lead on an old CHEAP wiring loom for the L494 shifter - I could use that as the male side of a pigtail (short wire loom that converts one plug to another) The female side of the pigtail... is tougher. I may have to get another spinny knob and cannibalize the connector - This is when I wish I had a 3D printer... If any of the experts on here know of where to get these connectors... Send leads my way!
Rolled Yahtzee Aug 2023 222,222Miles 2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel' Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted! 97K at purchase Sept of 2023 |
20th Oct 2023 3:19pm |
This is the place I use https://www.auto-click.co.uk/ there's probably a USian version - send them a photo of the connectors and they'll usually be able to work from that.
20th Oct 2023 3:29pm |
Thanks Phoenix!
20th Oct 2023 3:52pm |
One step closer...
20th Oct 2023 8:33pm |
At least some if not all of the wiring colours appear to be the same - I don't have any wiring diagrams for the L494 so I can't give you a pin-to-pin conversion table.
20th Oct 2023 8:44pm |
You'll have to check the measurements, I reckon this could be made to fit....
20th Oct 2023 8:58pm |
