Home > Maintenance & Mods (L405) > Alternative to L405 gear selector
Page 3 of 12 <123 4 ... 101112>
JDGeorgia
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
For $125... I can get another '16 wire loom...
Just butt connect into that...
Although the guy who sold me the shifter said he has a '15MY L405 on the yard... I may be able to get it cheaper from him. He is headed home for the weekend - but if I can't find the female - that may be the way to do this.
That may be deeper into the bowels of my truck than I would like to venture
The eBay pic of this L405 loom - not sure which is 7 wires... possibly this connector
 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Rolled Yahtzee Aug 2023 222,222Miles
2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel'
Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted!
97K at purchase Sept of 2023
Post #676011 20th Oct 2023 9:00pm
Phoenix
Well you could, personally I'd just spice the pigtail you have into the existing harness so you have both connectors available should you want/need to switch back to the original rotary gear selector.
Post #676013 20th Oct 2023 9:33pm
JDGeorgia
7 wires is a lot... if it were 4... I'd think about it.
Fabbing the pigtail is the most elegant way to go in my opinion...
I will check out that connector. I am sure that shipping will be more than the plug.
Hey now... what do we think about this?
https://www.amazon.com/AUTOHAUX-Female-Con...&psc=1
For $20 it may be worth a shot... 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Post #676020 21st Oct 2023 1:47am
Phoenix
Wrong pin size & spacing unfortunately.
Post #676024 21st Oct 2023 6:22am
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
Great work guys 👍 I admire your commitment , I am following this with great interest Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #676123 22nd Oct 2023 11:36am
JDGeorgia
One step closer, my brothers... one step closer to the possible end of the Maytag Delicates knob...
Phoenix - did I read that right? Did they really do 2 Green/Orange Wires?!?!? Which is which?
The mounting 'decks' appear to be 2mm higher in the front - if that is an issue, there is plenty of meat to grind down in the back, or use spacers up front.
If anyone want to donate to this madness... BOLO for a 12 pin female to mimic the bottom of the spinny knob - Phoenix 'reckons' this will work... https://www.auto-click.co.uk/6098-5277 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Post #676349 24th Oct 2023 6:55pm
Phoenix
Yes, there is - one is a 'single' the other is part of a twisted pair with the Grey-Blue. Just expose a bit more of the harness to find which one is the twisted pair.
Post #676350 24th Oct 2023 7:20pm
JDGeorgia
I am thinking it must be Pins 2&3 on my diagram... I could not find a marking to see the official Pin number...
The other Green/Orange is all by itself over by the Positive in Pin 9.
It just keeps getting better!!!
My Ebay Parts Friend... scavenged the connector off of a dead spinny knob...
I will have to get pins... but we are DANGEROUSLY close to making this happen 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Post #676355 24th Oct 2023 7:37pm
Phoenix
That would make sense - the way to confirm absolutely is to measure the DC voltage to ground, CAN lines will fluctuate 2-3V on each one. Difficult to say what the other one will be, probably a minimum of 4.5V but it will be steady.
Post #676363 24th Oct 2023 7:50pm
JDGeorgia
10/25/2023 - THIS POST HAS BEEN SUPERCEEDED - see the post on page 4 dated 10/25/2023 approx 17:25 GMT-5
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
This is a little busy - I apologize... If this actually works - I will clean it up and maybe do a video
Use this information at your own peril!!!
This is the original L405 Connector that I will unplug from the Spinny Knob.
The diagram is as if you are looking in the back where the wires protrude.
IMAGE DELETED - Incorrect Info - JDW
This should be correct - from Phoenix' Wiring Diagram
Here is what I think will be the pin to pin conversion:
IMAGE DELETED - incorrect Info
This just might work... 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Post #676375 24th Oct 2023 10:19pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Following this with interest, Lets hope you crack it. Jolly good luck Thumbs Up Thumbs Up
Post #676376 24th Oct 2023 11:46pm
Salsbury
Canada 2014 Range Rover 5.0 SC V8 Barolo Black
Let's get one thing straight, JDGeorgia. What you've done with that Range Rover isn't just tinkering in the garage – it's pioneering! And I've seen a few car projects in my time. This isn't just swapping out a headlight or getting posh leather seats. No, this is ground-breaking stuff!
If Land Rover had an actual hall of fame – and frankly, they should – there'd be a massive gold plaque with your name on it right at the entrance. A tip of the hat to you, sir! An absolute petrolhead legend you are!
Post #676380 25th Oct 2023 2:58am
Phoenix
That looks good to me, there will be a marking somewhere on the L494 plug to indicate pin 1, but your reasoning makes sense.
Post #676383 25th Oct 2023 6:13am
JDGeorgia
@Salsbury - flattery will get you everywhere!
I am sure if JLR gets wind of this there will be 6,354 warnings about no liability, cease and desist, covid vaccine, yadda yadda.
Jeep used to fully acknowledge shade tree innovators - Now they make 2WD Wranglers and encourage you to put rubber duckies on each other's hood. Tragedous I tell you... Tragedeous.
In today's litigious society - they have to crack a wry grin about this kind of stuff at home whilst enjoying a G&T. I will be honest - I have never had a Gin and Tonic, but if this comes off - I just may.
I stand on the shoulders of giants - Between the info dished out by Andy S, Bora 20, aljo and especially Phoenix - I am just the one stupid enough to try...
It is not done - YET. I am not the world's best with a soldering iron... and these are small wires. My fat sausage fingers don't work so well on tiny parts (ask the last iPad I tried to fix).
What does the Hive Mind think? 16GA wire? 18 GA wire? Solder and heat shrink?
I may have to solder up some test looms just to get back in practice...
Found this on how to use the RRS Selector - ?si=g58POh63pc9o3sbF
DrF - I think the "P" button on top is a shortcut to Park and not the parking brake. The video shows an EPB like we have.
Sitting on my bench - the selector will not dip left for Sport Mode - it must need to register the fact that it is in Drive to open that gate or something.
I may have to stop by my local friendly JLR 'Main' Dealer to test drive a '14 Sport - just to whette the whistle before I can get this wired up. 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Post #676385 25th Oct 2023 6:32am
JDGeorgia
I looked for a mark on the male L494 connector - if it is there, it is too small for these old eyes.
@Phoenix - do you have a link to possible 'Pins' for the L405 side? I don't think it is as small as 20ga wire... 16 or 18?
I am sure this plastic cover sat down on pins embedded in a PCB.
If we start mass producing pig tails (and we won't...) It might be worth it to see if that connector you had a link to would work. We would then have to find the 10 pin male L494 side. 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Post #676390 25th Oct 2023 7:16am
