Home > Maintenance & Mods (L322) > Trailer plug permanent live
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
I have recently fitted a 13 pin trailer plug complete with plug in harness,to my 2011 4.4tdv8, and was hoping to be able to keep my battery Topped up by connecting the CTEK to the plug. However pin 9 which should be the permanent live is dead. I have checked the plug connector in the wheel well and the is no life to that either. I have also checked the relevant fuses in the rear compartment and they are ok. Does anyone know where the permanent live gets its feed from.
Keith
Post #674476 28th Sep 2023 6:06pm
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
Would it not be a permanent live with the ignition on/car running ?
Seems a bit daft if it had a "real" permanent live because you could spend a day in a city with the big white box behind it parked up and find all batteries flat when you return to it.
Post #674480 28th Sep 2023 6:17pm
Dtech
Thanks for the reply. I understand what you mean , but as far as I am aware there should be a permanent live other than the ignition live which can be used for battery charging purposes etc,
Post #674497 28th Sep 2023 9:07pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
The live feed is permanent even with car off and locked on pin 9.
Have a look at fuse 48 this is down as trailer battery? 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #674501 28th Sep 2023 9:49pm
garyRR
As far as I'm aware, on later vehicles with the advanced BMS (2010 onward), relays cut circuits to the rear when the BCM sleeps.
However, it's not difficult to run a positive cable to your 13P plug if you need this. Heatshrink solder a spade connector to the battery terminal, and run a cable across the back of the engine bay and through the grommet for the bonnet release (easiest one to get a cable through). Then just pull up the sill trims and run through, which will chuck the cable out in the rear fuse box area. 2015 Range Rover Autobiography 4.4 SDV8
Post #674507 28th Sep 2023 10:36pm
dhallworth
You don’t need to modify anything on the later cars.
We charge both of our 2012 cars through the trailer sockets without any issues using the C-Tek 13 pin adapter. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #674509 28th Sep 2023 11:16pm
DrRob
I charge my 2011 4.4 TDV8 via a Ctek MXS10 and an adaptor into the 12pin electrics.
It clearly works as you can see the "progress" on the Ctek MXS10 panel Thumbs Up
Ctek I have:
https://www.ctek.com/uk/battery-chargers-1.../mxs-10-uk
Similar sort of adaptor:
https://www.paddockspares.com/ctek-comfort...3cQAvD_BwE Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #674513 29th Sep 2023 8:08am
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
+1 Thumbs Up
Post #674520 29th Sep 2023 11:35am
Dtech
Thanks for all the help everyone. It was in fact as v8 Bob suggested, fuse 48 in the front fuse box which had blown. I incorrectly thought that the trailer fuses were in the rear compartment.
Happy now I can use the CTEK without unlocking the car.
Post #674581 30th Sep 2023 1:10pm
