![]() | Home > Maintenance & Mods (L322) > Trailer plug permanent live |
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 ![]() ![]() ![]() |
Would it not be a permanent live with the ignition on/car running ?
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 70 ![]() ![]() ![]() |
Thanks for the reply. I understand what you mean , but as far as I am aware there should be a permanent live other than the ignition live which can be used for battery charging purposes etc, |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 374 ![]() ![]() ![]() |
The live feed is permanent even with car off and locked on pin 9.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
As far as I'm aware, on later vehicles with the advanced BMS (2010 onward), relays cut circuits to the rear when the BCM sleeps.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3202 ![]() ![]() ![]() |
You don’t need to modify anything on the later cars.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
I charge my 2011 4.4 TDV8 via a Ctek MXS10 and an adaptor into the 12pin electrics.
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 507 ![]() ![]() ![]() |
Thanks for all the help everyone. It was in fact as v8 Bob suggested, fuse 48 in the front fuse box which had blown. I incorrectly thought that the trailer fuses were in the rear compartment.
