![]() | Home > General > What Did You Do In Your Full Fat Today |
Proftinkerpot Member Since: 23 Dec 2022 Location: County Antrim Posts: 196 ![]() ![]() ![]() |
So after almost 8 months of owning my 2012 Westminster, and having covered 6000 trouble free miles - this evening on the drive when I started the enginevi got a gearbox, drive train and restricted performance warning. The gear selector didn't pop up. I switched off the engine got out and locked and unlocked the car. I restarted the engine and still got the restricted performance warning and the dreaded orange engine light on the dash. So it will be a trip to my mechanic next week as I dont have a plug in diagnostic to read and clear the fault code. Hopefully it's something minor like a sensor that can be swapped out easily.
Kiss My Carbon Footprint Member Since: 19 Dec 2020 Location: Milton Keynes Posts: 130 ![]() ![]() ![]() |
Bought a LR bike carrier from fellow forum member and jolly nice chap belldarr.
landy95 Member Since: 04 Aug 2021 Location: Hall Green, West Midlands Posts: 79 ![]() ![]() ![]() |
Fitted a new genuine LR brake vacuum pump, this will hopefully eliminate the red arrows exhaust when I boot it as it also acts as a turbo oil lube scavenger pump. Fingers crossed. Also own a 1976 Land Rover 101 3.5 V8.
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 596 ![]() ![]() ![]() |
Fitted a mint pair of rims on the rear and rotated tires (inside out, front / rear).
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 229 ![]() ![]() ![]() |
Replaced both lower tailgate cables.
hogesar Member Since: 11 Aug 2023 Location: Norfolk Posts: 34 ![]() ![]() |
Having only recently bought her....
Had all 4 manifold hoses replaced with the white-lettering pipes earlier last week. Today had the iphone to bluetooth adapter delivered and tested. Should have replacement number plates delivered tomorrow (existing one's look tired and poor). Also got some paint to tidy up the tow bar which i'll hopefully do one evening this week. |
I replaced my left side cable which snapped last week. When I checked the right side it was like new so clearly had been replaced before I bought my Westminster. They seem to go in the same place. I sprayed a little white grease inside the rubber sleeve and the rubber cap ends to try and ward off moisture getting into it. |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 173 ![]() ![]() ![]() |
Fitted LED’s to the interior lights, reverse lights and number plate lights. What a difference they make, much brighter. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1686 ![]() ![]() ![]() |
Wire brushed and kurust 661’d my rusty steering gear support brackets, and topped up the lanogard under the car, great weekend for it before the dark days arrive!
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Made mine work by doing 550 mile in one go with one break of getting food, drink and petrol whilst towing this.
Seatown Member Since: 30 Oct 2020 Location: Mountains, seaside Posts: 90 ![]() ![]() ![]() |
Fixed a coolant leak as per Fisha's very helpful write up here www.fullfatrr.com/forum/topic66813.html
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2279 ![]() ![]() ![]() |
Just had Bodsy round and did gearbox both diffs and transfer box done on both l322's superb service as ever |
Huttopia Member Since: 26 Jun 2017 Location: Worcestershire Posts: 187 ![]() ![]() |
Towed someone out of one of the fields. They turned around in a field entrance, on a slope and then got stuck. Rather than sit there 2m away from tarmac, they opened the field gate and reversed into the field in the hope of getting a run up. Uphill. On wet grass. In a Ford Focus with 2mm on the front tyres. The lady came running up to the farm in a fluster, whilst the mid 20s son sat in the driver's seat. I've not had a vehicle with a screw in towing eye, and she didn't have a clue, so it took a bit of finding and fitting (reverse thread got me for a moment). Uphill, tight angle to get through the gate and I'm straight onto a lane a right angles, all of 6m from the gate. All a bit awkward but we got there after a fashion.
colalowe Member Since: 11 Jul 2021 Location: Lancashire Posts: 107 ![]() ![]() ![]() |
My Mrs bought me a Land Rover experience afternoon at the North Yorkshire site. Had a blast driving a brand new Range Rover around the track, was amazed at just what they can do especially as it was throwing it down and blowing a gale and on road tyres!! Fantastic day and well worth doing if you can, have learned so much about the Terrain response system and the best way to use the car. ![]() Previous 2007 BMW M5 E60 |
