![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
If it's from the front of the engine then check the oil pump seals. 2012 TDV8 Vogue (L322) |
Pdevlin Member Since: 28 Aug 2021 Location: North Wales Posts: 3 ![]() ![]() ![]() |
I think I have this common leak from the oil seals at the top rear of the engine. I am getting the burning oil smell particularly after couple of miles up a steepish climb and can see drops of oil on the exhaust.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2586 ![]() ![]() ![]() |
It looks to me that oil is coming from more than just the o-rings on that pipe fitting and therefore the oil cooler gaskets are leaking. However I found it easy enough to change just the o-rings initially anyway. |
Smoggie35 Member Since: 21 Nov 2022 Location: North Yorkshire Posts: 9 ![]() ![]() ![]() |
Agree with GreameS on this Paul. Clean up as best as possible around the pipe bolting area and bellow then replace the two seals(with viton!!). Run the car for a few days then re-inspect. You will still get the oil burning smell for a while. Don’t know where the hell the oil hides but it’s good and takes some burning off.
GraemeS Smoggie35, thanks for your replies I will order some o rings and start with that
I've just had to change mine's o-rings again after 5 years due to oil leaking down both sides of the back of the engine. The old o-rings had flattened somewhat but I was concerned as to how easily the fitting was refitted, albeit with a film of grease. I'm thinking that the harder Duro 90 might be a better choice of compound to keep its shape better and therefore keep sealing for longer. BS611 in Viton 90 is generally available.
I changed mine with BS611 in Viton 90 last week. They needed a firm push even with a film of oil. Fingers crossed that was the source of the leak.
Excellent! |
Garymcduff1 Member Since: 05 Sep 2023 Location: Wales Posts: 6 ![]() ![]() |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
The blue smoke from the secondary turbo is normal on this engine and unrelated.
Thanks for the reply garyrr, I have recently replaced the secondary turbo thinking turbo seals were cause of the smoke and now researching the secondary turbo oil drain modification to see if that helps. The turbo oil feeds are fed from the back of the oil cooler and around the back of the heads to the turbos so don't think that's the cause as the leak seams to in the V of the engine,is there a pcv valve on these engines that could be in need of replacement? I can find replacement for the petrol engines but not diesel. |
Sorry garyrr just seen you comment regarding the egr, I have resealed either end of the metal egr pipe thinking that could be the cause but still the same. Looks like I'll need to strip it down, clean and rebuild with all new gaskets and seals. |
Here's the same section of my engine bay, in case it helps pinpoint something which may be amiss on yours. It's dusty, but then it has done 155,000 miles.
Thanks garyrr, I'll get into mine on the weekend strip it down and hopefully find the problem, has anyone carried out the turbo oil drain modification? |
