Home > Maintenance & Mods (L322) > Oil Level Overfilled
Lordy9099
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Hi Guys,
Hoping you can shed some light on my oil level reading, so when I’ve been reading the oil level cold, it’s been saying Oil Level Overfilled, so I parked it up and bought an extractor and took out about 1L initially it showed 3/4 and then went to max so I thought job sorted, the following day I checked it again cold and it said overfilled again, so I removed another 1L and checked it again, the gauge didn’t move, so I’ve took out another 2L since and it’s still saying overfilled, is the reading a live read or does the engine have to be started for it to get a reading? Surely the most accurate read is when it’s cold, but does the engine have to be started for it to reset the gauge?
Thanks
Post #669852 26th Jul 2023 2:21pm
DrRob
Suck it all out now
Add 8.5L back in
Should read just over half when cold
Don't drive it until you've done the above as you might have removed too much now Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #669854 26th Jul 2023 2:49pm
DrRob
Sensor has been known to fail too. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #669855 26th Jul 2023 2:51pm
Lordy9099
Does that include removing the sump for the turbo drain? Also if you remove this plug and drain do you have to prime anything or does it run over from the main sump?
Thing is, initially when I did take some oil out, the gauge did drop to 3/4 then to max and stayed there, but the next day when I checked it again it said oil level overfilled again.
Thanks,
Post #669858 26th Jul 2023 2:58pm
JayGee
Forget about the turbo drain sump for now - just drain the lot and refill with 8.5-9L to make sure you are not underfilling an engine with a broken level sender. 2012 TDV8 Vogue (L322)
Post #669860 26th Jul 2023 3:13pm
DrRob
Don't over think it Wink Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #669864 26th Jul 2023 3:35pm
Thanks,
Lordy, if you took your car into JLR tomorrow for any service, they would only suck the oil out the top and refill with 8-9lrts.
So, as above. Don't overthink it for now! Simply suck the rest of the oil out and put 8ltrs back in and then recheck your digital level. This will give you proof your level sensor is working or not sir? Thumbs Up
Post #669899 26th Jul 2023 11:11pm
Lordy9099
Hi Guys,
Quick update I took all the oil out, it was indeed overfilled by about 4-5 litres of oil. Thankfully
It’s not been took many miles since it was last done so hopefully caught it before any major damage done.
Thanks for your help
Post #670095 30th Jul 2023 12:19pm
JayGee
How is it possible to overfill it by that amount? Who serviced it last? 2012 TDV8 Vogue (L322)
Post #670097 30th Jul 2023 1:24pm
Lordy9099
I haven’t a clue, it was some place in Scotland where the previous owner took it, thanks fully it’s only done a few hundred miles so hopefully hasn’t done any damage and I caught it early. Great example as to why I service all my new cars from scratch again
Post #670099 30th Jul 2023 1:45pm
Bloody hell! You were lucky! 👍
Post #670103 30th Jul 2023 2:40pm
Lordy9099
Think I would have known of any engine damage already or could it have done damage that hasn’t yet shown?
Post #670104 30th Jul 2023 2:41pm
JayGee
Any oil leaks? 2012 TDV8 Vogue (L322)
Post #670107 30th Jul 2023 3:28pm
Lordy9099
Not that I’ve seen
Post #670108 30th Jul 2023 3:29pm
DrRob
Name and shame that garage so folks can avoid them. That's insane 😳 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #670111 30th Jul 2023 3:51pm
