Home > Maintenance & Mods (L322) > Oil Level Overfilled |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4286 |
Suck it all out now
26th Jul 2023 3:49pm |
Sensor has been known to fail too. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
26th Jul 2023 3:51pm |
Lordy9099 Member Since: 22 Jul 2023 Location: Manchester Posts: 20 |
Does that include removing the sump for the turbo drain? Also if you remove this plug and drain do you have to prime anything or does it run over from the main sump?
26th Jul 2023 3:58pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3051 |
Forget about the turbo drain sump for now - just drain the lot and refill with 8.5-9L to make sure you are not underfilling an engine with a broken level sender. 2012 TDV8 Vogue (L322) |
26th Jul 2023 4:13pm |
Don't over think it Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
26th Jul 2023 4:35pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
Lordy, if you took your car into JLR tomorrow for any service, they would only suck the oil out the top and refill with 8-9lrts. So, as above. Don't overthink it for now! Simply suck the rest of the oil out and put 8ltrs back in and then recheck your digital level. This will give you proof your level sensor is working or not sir? |
27th Jul 2023 12:11am |
Hi Guys,
30th Jul 2023 1:19pm |
How is it possible to overfill it by that amount? Who serviced it last? 2012 TDV8 Vogue (L322) |
30th Jul 2023 2:24pm |
I haven’t a clue, it was some place in Scotland where the previous owner took it, thanks fully it’s only done a few hundred miles so hopefully hasn’t done any damage and I caught it early. Great example as to why I service all my new cars from scratch again |
30th Jul 2023 2:45pm |
Bloody hell! You were lucky! 👍 |
30th Jul 2023 3:40pm |
Think I would have known of any engine damage already or could it have done damage that hasn’t yet shown? |
30th Jul 2023 3:41pm |
Any oil leaks? 2012 TDV8 Vogue (L322) |
30th Jul 2023 4:28pm |
Not that I’ve seen |
30th Jul 2023 4:29pm |
Name and shame that garage so folks can avoid them. That's insane 😳 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
30th Jul 2023 4:51pm |
