Home > In Car Electronics (L322) > CarPlay for under £100
Page 2 of 5 <12345>
Snowy90 L322
United Kingdom 2004 Range Rover HSE Td6 Giverny Green
Thanks Stan,
being an older L322 any ideas what connections i have at the back? the CD changer has given up now and as far as i know there is no aux input although i have an aux button on the factory head unit?
Post #669783 25th Jul 2023 1:51pm
technically all you need is a power cable...
but if you want sound/music from your speakers then you could use the 'FM' channel route...you pick a FM frequency from the carplay unit and tune your radio to it..
not sure re the aux input method... ... - .- -.
Post #669787 25th Jul 2023 2:49pm
Snowy90 L322
Thanks worth looking into Thumbs Up
Post #669788 25th Jul 2023 2:50pm
Baltic Blue
I fitted the exact same Parrot phone kit in my td6, but that wouldn’t be needed with the modern CarPlay units.
I did think I had an Aux socket in the rear but can’t be 100% certain, but as Stan says tuning the radio to a spare FM slot works perfectly well.
and it is easy to route the 12v feed to the rear socket through the glovebox and between the front seats under the carpet so that it just pops out directly below the rear socket if you buy a 12v cigarette socket extension lead off eBay .
Post #669789 25th Jul 2023 3:27pm
Snowy90 L322
Hi
I did read about an aux socket in the central console at the back with the 12v socket but i couldn't find anything or do you mean at teh rear of the head unit?
eitherway i would be happy with the FM route tbh.
Do all of these units have the FM tune option? or do you need a seperate bit of kit?
Be nice to get rid of that Parrot and the little speaker in the footwell, which makes me think i do not have an aux input unless they were being lazy.
Post #669796 25th Jul 2023 4:31pm
garyRR
That looks really neat madnessgonemad.
I am planning a big operation, (the blower replacement) and whilst I'm at it and got the dash out, plan to install the latest retrofit touch screen that's just been released (does all the 4x4 settings etc), 360 camera system with blindspot monitoring, and the digital climate screen.
Will post the results when all the parts have arrived and the job is done. 2015 Range Rover Autobiography 4.4 SDV8
Post #669799 25th Jul 2023 4:38pm
mjdronfield
On the 2004 car, depending on if the radio has been upgraded as an option, there might not even be a centre speaker under the grille on the HSE. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #669804 25th Jul 2023 5:15pm
TorontoDee
Canada 2012 Range Rover Westminster 5.0 SC V8 Santorini Black
Looking forward to hearing/seeing it. What's the latest touch screen going for? 2012 Supercharged L322
Post #669819 26th Jul 2023 12:59am
Snowy90 L322
It is an HSE, but i think had an upgraded sound system, i will have to take a peak under it now!
Post #669832 26th Jul 2023 10:26am
madnessgonemad
stan wrote:
this is an install from a member here,
https://www.fullfatrr.com/forum/post663042.html#663042
another install option here from baltic blue [mike],
I don’t like wires showing!
Post #669851 26th Jul 2023 2:08pm
that particular setup had the usb cable in for phone connection...
the unit is capable of wireless connection so you only need one power cable which is easily hidden in the trim.. ... - .- -.
Post #669856 26th Jul 2023 2:53pm
mjdronfield
I believe that if you have DSP as an option on the screen, there will definitely be a speaker under the grill. I think there were 3 options fo hifi on the early cars. Not sure if the mid option had a speaker or not, but DSP system def does. Entry level has no speaker.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #669862 26th Jul 2023 3:22pm
Vadge
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Love what you've done here, This has given me hope!! Happy Days..
CURRENT : FFRR 2010 3.6 TDV8
CURRENT :Mercedes SLK350
GONE : NISSAN X-TRAIL
GONE : BMW 630M CONV
GONE : BMW 530D
GONE : BMW 321 CONV
GONE : ALPHA ROMEO 156
GONE : 1998 JEEP CHEROKEE
GONE : MK2 FORD ESCORT
GONE : 1980 VW BEETLE
Post #679062 29th Nov 2023 7:02pm
drphilgarner
United Kingdom 2011 Range Rover Vogue 4.4 V8 Buckingham Blue
There are definitely some nice options on aliexpress now for a reasonable price - worth a look. 2011 4.4 TDV8 Vogue
Post #685524 13th Feb 2024 9:31am
Driyage
@madnessgonemad I’m looking to do the same as you’ve done to install a CarPlay screen in my L322
So just to clarify, you’ve taken out the centre vents, blocked with foam, laid a base plate and stuck the screen stand to it and covered the again with a black top plate?
Thanks
Post #695697 7th Jul 2024 1:49pm
Page 2 of 5 <12345>
