![]() | Home > In Car Electronics (L322) > CarPlay for under £100 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35542 ![]() ![]() |
technically all you need is a power cable...
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 224 ![]() ![]() ![]() |
Thanks worth looking into |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3789 ![]() ![]() ![]() |
I fitted the exact same Parrot phone kit in my td6, but that wouldn’t be needed with the modern CarPlay units.
Hi
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
That looks really neat madnessgonemad.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7880 ![]() ![]() ![]() |
On the 2004 car, depending on if the radio has been upgraded as an option, there might not even be a centre speaker under the grille on the HSE. 2011 Range Rover Vogue SE 4.4 TDV8
TorontoDee Member Since: 27 Sep 2022 Location: Toronto Posts: 77 ![]() ![]() ![]() |
Looking forward to hearing/seeing it. What's the latest touch screen going for? 2012 Supercharged L322 |
It is an HSE, but i think had an upgraded sound system, i will have to take a peak under it now! |
madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 104 ![]() ![]() |
I don’t like wires showing! |
that particular setup had the usb cable in for phone connection...
I believe that if you have DSP as an option on the screen, there will definitely be a speaker under the grill. I think there were 3 options fo hifi on the early cars. Not sure if the mid option had a speaker or not, but DSP system def does. Entry level has no speaker.
Vadge Member Since: 29 Nov 2023 Location: Surrey Posts: 2 ![]() ![]() ![]() |
Love what you've done here, This has given me hope!! Happy Days..
drphilgarner Member Since: 20 Sep 2022 Location: Lancaster Posts: 32 ![]() ![]() ![]() |
There are definitely some nice options on aliexpress now for a reasonable price - worth a look. 2011 4.4 TDV8 Vogue |
Driyage Member Since: 30 Apr 2024 Location: Essex Posts: 42 ![]() ![]() |
@madnessgonemad I’m looking to do the same as you’ve done to install a CarPlay screen in my L322
