![]() | Home > Maintenance & Mods (L322) > Tow bar retaining pin needed - see pic |
nicam Member Since: 23 Nov 2016 Location: Lancashire Posts: 9 ![]() ![]() ![]() |
Does anyone have a source for the bolt? Or a part number?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35478 ![]() ![]() |
i'm sure any reputable tow bar supplier/installer should have that bolt...try pf jones...
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1541 ![]() ![]() |
Aussie tow bars usually have a bolt which can be tightened to stop the rattle of the tongue in the receiver. Ron B. VK2OTC
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
Simple solution is to drill a small hole in the receiver , tap a thread and screw a bolt in of correct size, the bolt can be tightened until it grips the tongue and rattle is gone . or alternative drill a hole and weld a nut to the receiver and screw a suitable bolt in.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8678 ![]() ![]() ![]() |
^as above, not a good idea to be drilling type approved bars, it will most likely invalidate your insurance should anything go wrong. |
JavaBlack Member Since: 07 Sep 2016 Location: UK Posts: 67 ![]() ![]() ![]() |
Hi Alistair, Do you have a part number for the threaded one? Many Thanks. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 ![]() ![]() ![]() |
I'm not sure they had different numbers - or were just considered different versions of the same part.
Thankyou for the reply Alistair, I have emailed Westfalia UK (now owned by Witter) so will report back with the findings. Out of interest, what side was the thread on?
Sorry - I can't remember back that far |
