Home > Maintenance & Mods (L322) > Tow bar retaining pin needed - see pic
This tower design evolved - I had 2 of the 3
The earliest versions came with a pin. This was later swapped to a bolt to reduce rattling. Mine came with a bolt, but I replaced with a pin as I rarely used it & valued removability over the rattling.
The later versions were supplied with a thread through 50% of the hole in the piece you insert, so you had to screw the bolt in and then add an additional nut. It was a PITA to remove, but didn't rattle.
Both LR supplied bolts had a hole for an additional retaining clip, which could be placed with a small padlock
Ian is correct though - it's illegal to modify a type approved tow bar.
The original -
The threaded one -
The bolt -
Post #413204 12th Nov 2016 11:54am
nicam
United Kingdom 2003 Range Rover Vogue Td6 Epsom Green
Does anyone have a source for the bolt? Or a part number?
My bar has been swapped from a swan neck to the "farmers" adjustable and the original bolt doesn`t fit because of the thread in the removeable part. I need the bolt with thread 2/3rds of the way up the bolt, but with the shoulder to take the contact - exactly as the one shown in the pic above.
I can get a fully threaded set screw but it can`t be as strong and will fret the thread against the fixed part of the bar, I reckon. I would prefer to stay as the original design but can`t source the bolt from my normal places.
Thanks
Nicam Don`t drive faster than your Angel can fly.
Post #442291 22nd Jun 2017 11:40am
i'm sure any reputable tow bar supplier/installer should have that bolt...try pf jones...
https://www.pfjones.co.uk/tow-bars.html ... - .- -.
Post #442293 22nd Jun 2017 11:58am
p38arover
Australia
Aussie tow bars usually have a bolt which can be tightened to stop the rattle of the tongue in the receiver. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #442363 22nd Jun 2017 10:05pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
Simple solution is to drill a small hole in the receiver , tap a thread and screw a bolt in of correct size, the bolt can be tightened until it grips the tongue and rattle is gone . or alternative drill a hole and weld a nut to the receiver and screw a suitable bolt in.
see pic
Post #442390 23rd Jun 2017 9:22am
^as above, not a good idea to be drilling type approved bars, it will most likely invalidate your insurance should anything go wrong. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #442463 23rd Jun 2017 6:00pm
JavaBlack
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
The original -
The threaded one -
The bolt -
Hi Alistair,
Do you have a part number for the threaded one?
Many Thanks.
Post #669281 17th Jul 2023 4:00pm
I'm not sure they had different numbers - or were just considered different versions of the same part.
Maybe 323063 ?
I doubt you'll find a new one anywhere, so if buying used, I guess you're relying on a photo ?
Post #669286 17th Jul 2023 5:03pm
JavaBlack
Thankyou for the reply Alistair, I have emailed Westfalia UK (now owned by Witter) so will report back with the findings. Out of interest, what side was the thread on?
Many Thanks.
Post #669287 17th Jul 2023 5:29pm
Sorry - I can't remember back that far
Post #669288 17th Jul 2023 5:45pm
