![]() | Home > Technical (L322) > 4.4 tdV8 Starter motor investigation. |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 349 ![]() ![]() ![]() |
So I finally got this all cleaned up and back together, refitted. All in all it took me way more than 3 hours, more like 7 or 8!
Well, there's basically three nuts holding the cover on, but then two electrodes that protrude through the cover, one just slides in but the second is the difficult one - pictures above with the chisel next to it.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
thx Siftah, I got it off. no breakages!
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3182 ![]() ![]() ![]() |
I’ve only just seen this thread.
I did mate, I stripped it right now and cleaned all the threads and surfaces that contact each other. Have a look at this video he gives a great set of instructions; &t=629s Especially the bit about taping everything up to avoid getting copper dust in everything! |
It did look like it should fit, but I couldn't get it too tbh. I concentrated on getting it out through the side as that's what I'd seen recommended though, so perhaps I didn't spend long enough trying to get it out through the bottom, dunno ![]() |
I can't work out how to remove the propellor-shaped contact but don't think I need to.
I went for smooth as it's what he did in the video and I have no easy way of creating a knurled surface.
Siftah yes trigger cable sorry Cheers, Greg
Guys what kind of contact grease should I apply to the cleaned copper contacts?
Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
just to update, I've now done this with a dead starter off ebay, took it apart, revitalised the contacts, used the contra-lube then finally got the car up on a jack on the weekend, wheel off, undertrays etc off and with some wrestling the starter came out through the triangle shaped subframe gap directly under the starter. The gap under the the arch where the anti-roll bar did not come close to letting the starter through. So far is't working a treat and a £30 fix so well pleased. Cheers, Greg
DeeJay Member Since: 16 Oct 2021 Location: Western Cape Posts: 38 ![]() ![]() ![]() |
Can those that went ahead to file off / clean the solenoid copper contacts tell us if this is a lasting long term solution? If it needed to be done again, how long after? 2011 Vogue SE 4.4 TDV8 |
Having just done mine, I am wondering the same |
Garymahoo Member Since: 15 Jul 2022 Location: Aberdeenshire Posts: 49 ![]() ![]() |
