![]() | Home > Technical (L322) > 4.4 tdV8 Starter motor investigation. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Guys, have you read this thread? It ‘ends’ with a solution on running a parallel cable for the triggering wire… which has an inherent high resistance, that doesn’t seem to have ever been found, but fixed by running the second parallel cable from fuse box to starter motor. I had the issue, (like many) and changed starter but it remained… ran the paralllel cable and had no issues at all since. Here. (takes about 1/2 hour, and a £5 small reel of cable from Halfords) https://www.fullfatrr.com/forum/topic31909-75.html |
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 88 ![]() ![]() ![]() |
Any update for the longgevity of the contacts that have been cleaned?
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
did mine in August, working beautifully Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Cheers, I have just gave this a go. Got the started unbolted (what a pain) , and trying to pull it forward out of its housing now.
it take patience, many rotations and twists etc to get the right orientation to come out.
Thanks, I was pushing it back against the rubber pipe but could not get the teeth past. Will give it a few twists and see how it goes! |
Wiltshire130 Member Since: 05 Aug 2023 Location: Wiltshire Posts: 27 ![]() ![]() ![]() |
However hard I tried I could not get my starter motor out.
Update, my parallel wire did not fix the fault, but cleaning up the heavily burnt contacts did. Started each time since so hopefully this will last a fair few miles.
DeeJay Member Since: 16 Oct 2021 Location: Western Cape Posts: 38 ![]() ![]() ![]() |
Would like to give my update to this thread.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2661 ![]() ![]() |
I attempted to extract mine to check the contacts when the starter had to be removed to fit a crankshaft locking tool but I lost patience trying. It was difficult enough to just get it to where I could fit the tool. |
Shovie Member Since: 04 May 2021 Location: Wickwar area Posts: 14 ![]() ![]() ![]() |
Hi,
Energising the solenoid makes the high current connection to the main motor, but it also actuates the motor itself, so the spindle is pushed forward and the teeth engage.
Joined the battle of the starter motor removal club today and sure enough the solenoid contacts are the issue. Does anyone know where the permanent live to the alternator is sourced from the live to the starter? My other thought was to move the live to the other solenoid terminal, add a solenoid to the feed on the bulkhead but without knowing where the live to the alternator supply is that idea is a non starter. |
James23 Member Since: 10 Jul 2024 Location: East Midlands Posts: 9 ![]() ![]() |
I'm about to have to tackle this job myself as I had a click a few times in the last week.
