![]() | Home > Technical (L405) > Ride quality -16 SDV8 AB |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 693 ![]() ![]() |
Hi Graeme,
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2562 ![]() ![]() ![]() |
I wouldn't be moving the arm by hand but perhaps graph that sensor while driving slowly on a smooth surface to see if it is still jumping about. I wouldn't expect the extent of the variation to cause the stiffening of a shock but you might want to graph that shock's and possibly the other side's demanded duty cycle/s to see if there's corresponding shock valve operation. |
Okay I'll graph all the sensors whilst driving tonight and also try a comparison with shock duty cycle.
Only 1 sensor with the signals shared by both EAS and CVD. The dual sensor was only for L322s fitted with CVDs as an after thought. |
I thought as much Graeme, so when in viewing height sensor voltages as reported by CHCM these are the voltages that both the EAS and CVD use? |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 337 ![]() ![]() ![]() |
That certainly doesn't sound right. Mine doesn't do that. 2017 4.4 SDV8 Autobiography in black 2018 D300 SE Velar in champagne 1982 Rolls Royce Silver Spirit in green Spiffing wheel centre caps, L322 sill repair panels, etc |
Yes, EAS & CVD use the same signal/volts. |
Mine does unfortunately Stuart. In fact the whole car shakes like a defecating dog at motorway speed and yet my 40 year old Ford doesn't.
I've graphed the height sensor voltages driving on a relatively smooth road at 25mph for 20 seconds.
I would definitely get the vibration resolved. It will rapidly accelerate steering and suspension component wear and can adversely affect the shock behaviour, let alone your comfort. The cause could be wheel balance, a bent rim, wheel alignment, loose suspension bushes, worn-out shocks or the transfer case or rear e-diff clutch binding. |
Oh believe me I've tried Graeme.
In that case it seems like there is at least 1 useless shock. Do you know which corner is causing the vibration? If the rear then remove the bottom shock bolt and see if you can compress the shock. If it can be moved 1 cm by hand without great effort while still attached then it will be useless and the other side might not be much better.
That's another thing to look into then Graeme, thank you.
Another quick query...
