![]() | Home > Technical (L322) > 4.4 tdV8 Starter motor investigation. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Good morning Greg,
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Thanks Mike!
actually I think my plan was a dud anyway, the 1207 looks quite different....
Sorry Greg, I can’t remember what I paid, but I know I got it from Opie oils when they had a 15% off offer.
Reading up and chatting to a few members, seems like three choices:
I intended to keep the one I repaired as a spare, but gave it away when I was moving house, because I had already fitted the new one I bought from Opie.
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 347 ![]() ![]() ![]() |
In the middle of doing this job at the moment, the 17mm nut that holds the wires onto the starter is a right pain to get too, been at it about 2 hours and can't get it loose |
How are you doing Greg ?? are you in yet ?
I'm stuck at this bit now - I think I've not got the anti-roll bar as low as I've seen in other pictures, but how? I tried jacking the car in both access mode and off-road mode but the anti-roll bar seems about the same height both times. It seems like the higher I jack the car off the ground the low the bar is, but never as low as shown in the pics here, any tips!? ![]() HALP! ![]() |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1213 ![]() ![]() ![]() |
I have only worked on a Td6, so bear with me, one option if it will not 'wiggle out' could be to disconnect the anti roll bar from the drop links, that way you can pull the anti roll bar down, looking at your photo this will probably be enough to get the starter out. However, better advice will probably be along soon from someone who owns a TDV8. |
Stupid question time - the "drop link" is the near vertical bar that runs in-front of the drive shafts, right?
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1351 ![]() ![]() |
Yes, those are the drop links, careful with the washer at the top... |
Thanks chaps, will give that a go tomorrow! |
Just be careful not to wreck the rubber covers or you could end up having to replace them, but they are easy and cheap to replace. To remove the end pull the rubber back there should be two flats to fit a spanner on then use a spanner / socket on the retaining nut. |
