![]() | Home > My Range Rover > Roastpenguin's 3.6 |
RoastPenguin Member Since: 11 May 2023 Location: West Midlands Posts: 29 ![]() ![]() |
Thought I'd start me own thread in here
Yikes! How did I not feel that! Nice easy fix though...checked the LH hose all was well but I'll replace both. Hopefully thats that put to bed... Both upper hoses had a film of oil, anything to worry about?
RH throttle body, couldn't get decent pic of left side but was slightly cleaner
MAP sensors before and after a quick blast with contact cleaner. I didn't check MAFs as I don't have dedicated MAF cleaner and wasn't sure using the general stuff
Both MAP plugs had this white residue in them, any concern?
Also glued a section of bonnet/scuttle seal back down, checked me towing mirrors fit and checked battery voltage as receipt for the genuine LR battery was from 2019. I got 12.5v engine off, 13.4 at idle and 13.4 at 2k rpm. I've read all sorts r.e alternator output so not going to panic on that yet. 'Whipped' the battery out...well, it took 10mins to get the 2nd clamp bolt out. Some bellcheese had bent and cross threaded it!
After clean up and recut the threads on bolt and in battery tray
Not pretty but threaded back in ok 👌 The audi is being picked up next week by a trader, it had a new 110ah 920 A (current one in Range is 90ah 850 A) fitted 12months ago and I've still got the old one it replaced. I never tried charging it at the time so thats on charge now and looks like it should be good enough to go back in, hopefully freeing the good one up for the FF 😁 it is bigger than the current battery, 395x175x190mm approx, tape measure says it will fit, just.... Well if you've got this far, cheers. Any advice most welcome Sorry for pic heavy post but it gets boring reading a wall of text 😆 |
Cheers @Barmybrummie (don't know if tagging you in will work)
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 737 ![]() ![]() ![]() |
Hopefully with a bit of luck your egrs may already have been blanked off. If not, it's a very easy job to do, I did my own just after I bought mine.
Hopefully something daft like a belt squealing, fingers crossed for ya |
New RH intercooler hose fitted today
After wire brush, rust converter and couple of coats of hammerite i had knocking about
And new big boy battery fitted!
(I did bolt that other clamp in!) Took a bit of persuasion but its a good fit, car started well after nearly 2 days with battery off, did feel a bit lumpy on idle and had 'special programs unavailable' flash up but soon cleared up. Went a little test drive, no engine system fault, smoke or what have ya ![]() Ordered a headlight renewal kit today, need to get tyre balances checked though as when I'm doing 60-70 there's a slight constant judder. Can't really feel it thru the wheel but more thru the seat. More of a vibration really. Hoping tyre balances rather than prop but I'll start with the basics... |
Gratuitous pics on a local lane
Love the look of these, getting to be a modern classic I reckon, especially the early ones ![]() Coming out of an Audi on s-line suspension and low profiles into this is proper twisting my melon man ![]() |
Got the towbar armature fitted today, excuse the white sealant it was left over from the caravan
I'm not using the electrics in the kit, I'm getting a pro to fit 13pin with proper module and towing mode switched on Bumpers still off, got to repair one of the clips broken by previous removal ![]() Can anyone tell me what this is?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
its a TPMS sensor... ... - .- -.
Ahh course, the antenna for it? Thanks v much |
Fixed a previous bodge with a slightly better one
Thought the wet patch on the drive was a/c condensation. Got off my arse when I noticed coolant had dropped and here's the culprit.
Yeah nice one 👌🏻 Its the U shaped hose comes off the bottom of expansion tank. Guessing it wore thru and got fantastically bodged. Quick Google and call to LR revealed it only comes as part of that larger assembly circled. £450 from LR and about £250 from European parts suppliers. **** that ses I...
Pirtek Wolverhampton, length of 19mmID hose, a coupling and few jubilee clips for 13 quid.
So thats the idea. Same as the last bodge really just a bit more disassembly and care taken... Bled system as per workshop manual for expansion tank removal and refitting, heres the join with engine running
I supported the longer length with a couple of cable ties to keep the join square, one of those things I'll check neurotically for the next few weeks 😅 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Definitely blank both EGR valves on a 3.6 with a simple kit off eBay etc |
Absolutely, already got an empire tuning egr kit ready! I've got a gearbox oil leak, all around the pan by the looks of it. The plug connector seal above looks OK....does bodsy do the pan and filter changes as well or just mega flush? Diff an trans case oils are on the list but thats diy for me. I can do the gearbox pan but not sure if icarsoft lr2 will read temp for refilling?? Also need new prop as centre bearing failing and I tow so might as well throw a new genuine one on. Its up in the air at the minute whether I do prop and gearbox service myself or try and get it in the local indy but they're booked out solid.... |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Make sure you replace the UV protection or the Plastic lens will deteriorate 10x quicker than last time sir... ![]() |
Cam-tech Craig on my thread?? It's an honour sir!😆
Thats the badger aint it? Cant quite bring myself to do the headlights while the prop centre bearings flapping in the wind and gearbox is enthusiastically marking its territory 🤣🤣 |
