Home > My Range Rover > Roastpenguin's 3.6
Te he… Your welcome sir 🫶
I’ve only ever used the services of either an Aston Martin paint shop, who specialise in spraying a special UV clear lacquer developed for AM plastic headlamps. Or. Having the front’s clear PPF style wrapped using a UV branded PPF sir…
Not sure my rattle can skills would look very good!?! Unless there’s something I’m missing? And the clear coat is a breeze to use?
Post #666410 12th Jun 2023 9:45am
RoastPenguin
Hmm, plenty of masking tape and a steady hand then. I'll update when I get around to doing them, review the holts kit for you all.
Just been quoted £250 labour to fit new prop and gearbox service inc mechatronic sleeves/seal replacement and general check over by a local indy 👍🏻 couldn't get me in until end of July so hope thats a good sign... 3.6 TDV8 Java Black
Post #666414 12th Jun 2023 10:39am
That seams very cheap to me… Just make sure they are not cutting corners on quality of parts they are using sir… Rolling Eyes
Post #666427 12th Jun 2023 12:26pm
dingg1
Cost more in parts, I reckon they have missed a 1 off the front 😂😂😂
Post #666428 12th Jun 2023 12:30pm
RoastPenguin
Nooo thats just labour. I'm supplying parts. Genuine prop from advanced factors over 400 and a genuine zf kit with lifeguard oil, 300 notes 3.6 TDV8 Java Black
Post #666430 12th Jun 2023 12:38pm
RoastPenguin
See above, there'll be 4 digits in total!😆 3.6 TDV8 Java Black
Post #666431 12th Jun 2023 12:39pm
dingg1
Post #666432 12th Jun 2023 12:45pm
Apologies sir… Bow down
Post #666436 12th Jun 2023 2:00pm
RoastPenguin
Got one of the headlights refurb'd yesterday 👍🏻
Before
After
Not too bad tbf
I used an autoglym kit on a mates last year, better results than this holts kit so out of the 2 id recommend autoglym. I'll see how these go with repeat periodic applications of the sealer then I might try a meguiars kit if they fade again 3.6 TDV8 Java Black
Post #666902 18th Jun 2023 11:49am
RoastPenguin
GKN rear prop and ZF gearbox kit arrived today 😀
Genuine filter kit with proppa oil and mechatronic seals, 300 notes from www.gearboxoils.com , they've got an ebay store and do all sorts of gearbox stuff, not just oils if anyone needs anything!
Genuine rear prop from AF was just over £460 delivered 👍🏻forgot to use forum discount if it still applies 🤦🏻‍♂️
Fitting end of next month, 2 days before I need to tow the caravan 😬😬😬
Jobs for future include thermostat housing, rocker cover leaks, 1 or both heater control valves, rear hub bushes and a part worn pirelli on drivers rear if I can find one...*
*(this list is not exhaustive )🤣 3.6 TDV8 Java Black
Post #667800 28th Jun 2023 6:53pm
RoastPenguin
Its all gone wrong 😪
Got combustion gases in the coolant, white smoke under load when cold
Cam cover gaskets pìssing oil out, and strangely there's beads of coolant present when you wipe your finger along the cam cover/head join
Thermo housing is cracked
And 1 oily MAP sensor with P023D-22 on the same bank so potential turbo failing
My indy has quoted minimum £3500 to pull the engine, do head gaskets, turbos and cam covers plus associated bits
So I've made the decision to break it 😪
If anyone needs anything let me know 3.6 TDV8 Java Black
Post #677617 9th Nov 2023 5:43pm
That's a great shame, you were sorting it all out so well...
As a matter of interest how many miles has it done..?
If I were you I'd start another thread in the for sale section, you'll get more views... Thumbs Up
Are you going to get another fatty..?? Pete
Post #677657 10th Nov 2023 12:19pm
RoastPenguin
Thanks for your kind words, appreciated 🙂 I did feel like it was getting to be a good un...
172k miles mate, I've got back into a D2 with my tail between my legs!
Good shout, I'll get it on the level drive up the side of the house and get a thread in for sale section. Think I've got enough posts now. Need to get axle stands back off my mate actually....
Bit of a blow because it was such a great family car and towed fantastic. 3.6 TDV8 Java Black
Post #677685 10th Nov 2023 9:10pm
