![]() | Home > My Range Rover > Roastpenguin's 3.6 |
RoastPenguin Member Since: 11 May 2023 Location: West Midlands Posts: 29 ![]() ![]() |
Thought I'd start me own thread in here
Cheers @Barmybrummie (don't know if tagging you in will work)
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 724 ![]() ![]() ![]() |
Hopefully with a bit of luck your egrs may already have been blanked off. If not, it's a very easy job to do, I did my own just after I bought mine.
Hopefully something daft like a belt squealing, fingers crossed for ya |
New RH intercooler hose fitted today |
Gratuitous pics on a local lane
Got the towbar armature fitted today, excuse the white sealant it was left over from the caravan |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35647 ![]() ![]() |
its a TPMS sensor... ... - .- -.
Ahh course, the antenna for it? Thanks v much |
Fixed a previous bodge with a slightly better one
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Definitely blank both EGR valves on a 3.6 with a simple kit off eBay etc |
Absolutely, already got an empire tuning egr kit ready! I've got a gearbox oil leak, all around the pan by the looks of it. The plug connector seal above looks OK....does bodsy do the pan and filter changes as well or just mega flush? Diff an trans case oils are on the list but thats diy for me. I can do the gearbox pan but not sure if icarsoft lr2 will read temp for refilling?? Also need new prop as centre bearing failing and I tow so might as well throw a new genuine one on. Its up in the air at the minute whether I do prop and gearbox service myself or try and get it in the local indy but they're booked out solid.... |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Make sure you replace the UV protection or the Plastic lens will deteriorate 10x quicker than last time sir... ![]() |
Cam-tech Craig on my thread?? It's an honour sir!π
