![]() | Home > Technical (L322) > Lower thermostat modification V8 4.4 M62 2002-2005 |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1553 ![]() ![]() |
Just following up on fitting a resistor to fool the ystem into believing the heater element is still there and thus stop the fault being recorded:
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8513 ![]() ![]() ![]() |
p38arover, you must be very OCD to worry about a soft fault that throws a code that can only be read with diagnostics and doesn't give any warnings on the dash...
Just OCD. |
Totally understand, that's fine.... |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 899 ![]() ![]() ![]() |
Am a bit late to the party - but finally got hold of a BMW part made by Mahle - it's the 88deg thermostat one and installed it without any probs |
OsloBlueM62 Member Since: 24 Sep 2024 Location: Leicestershire Posts: 1 ![]() ![]() ![]() |
Looking at doing this MOD along with refreshing the cooling pipework. I have been on the ABBES Performance website, but I cannot see how you actually order one. I have emailed them but several days later no response.
Doesn't matter how you do it, just get the temp down and your fatty will thank you.... |
I did the mod a few years back but later replaced it with the 88 deg C thermostat. It's a bettrer way to do it and there's not much difference in price. Ron B. VK2OTC
andyrosehome Member Since: 06 Jan 2018 Location: South Wales Posts: 14 ![]() ![]() ![]() |
Hi Folks.
Pleased it has helped you, it's a weird feeling when you first drive it and difficult to describe but the engine is thanking you...
