![]() | Home > My Range Rover > My 2005 4.2 Supercharged - here we go.... |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 395 ![]() ![]() ![]() |
... I was certainly losing mine last night ![]() 2005 Range Rover Vogue SE 4.2 Supercharged V8 Follow my 4.2 Supercharged antics - https://www.fullfatrr.com/forum/topic63354.html https://www.instagram.com/l322_supercharged/ https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg https://www.youtube.com/@ChallengingClassics |
I've been looking for one of these to fit in my centre console for a few months and one popped up on Ebay. Its just arrived in very good condition - I like a bit of 'Retro-Phone-age'
Will fit it later when I get it back from it Re-gas. Gavin 2005 Range Rover Vogue SE 4.2 Supercharged V8 Follow my 4.2 Supercharged antics - https://www.fullfatrr.com/forum/topic63354.html https://www.instagram.com/l322_supercharged/ https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg https://www.youtube.com/@ChallengingClassics |
After seeing these fitted by fellow forum member - I think it was Caesium - I fitted these new Horns from Hella. £18 from Amazon - https://www.amazon.co.uk/gp/product/B001CC...&psc=1 Removed the plastic retaining clips under the front splash shield in the wheel arch, Headlights, removed the bolt holding the bumper and the bolts that hold it in place along the top front and one below the grill. Gently prized it off and away which allowed enough room to remove the existing Horn bracket and swap over the horns over to the new ones. The connectors were different and I'm not happy with how I've terminated the existing wires so will revisit at some point, but its all I had at the time. They do sound rather good
I had to remove the black brackets on the new horns -
So, not posted for a while as the SC is running well but yesterday was its 1st MOT under my ownership (6 months now)...
Pleased to say it flew threw ....
and the advisories on the previous MOT all addressed (in this thread) ![]() 2005 Range Rover Vogue SE 4.2 Supercharged V8 Follow my 4.2 Supercharged antics - https://www.fullfatrr.com/forum/topic63354.html https://www.instagram.com/l322_supercharged/ https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg https://www.youtube.com/@ChallengingClassics |
Oil service coming up but before I do that I had a spare hour so decided to do an oil service on the Supercharger.
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Just ordered the kit for mine. Will be interesting to see the state of the oil that comes out. 83000 miles on mine now. Previous cars:
Oil change done today. Good call on using rag to prevent loss of plug/Allen key. Bit of a faff getting the pipe as far down into the bottom of the supercharger as possible (had to warm the end of the hose to make more flexible) but managed to get between 175 and 180 ml of oil out. The oil, although it was dark, looked to be in a reasonable condition. Filled up with 180 ml of fresh oil.
I found it difficult but a trick I found was to magnetise the plug before putting it on the end of the 3/16 Allen key - it seemed to hold it enough to get it in place and then turn it gently to start it off. In saying that I still dropped the Allen key down the side ![]() 2005 Range Rover Vogue SE 4.2 Supercharged V8 Follow my 4.2 Supercharged antics - https://www.fullfatrr.com/forum/topic63354.html https://www.instagram.com/l322_supercharged/ https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg https://www.youtube.com/@ChallengingClassics |
Got it started with the Allen key but had plenty of attempts to get it into the right position to marry the thread starts up. Good job the missus wasn't there to hear my fruity language. Previous cars:
Last oil and filter change on my SC was back in November 2021 by Land Rover Wimbledon at 79k so it was time to change the oil and filter before winter sets in.
8.4litres in and its just below the max after 20 miles. That's all the oils changed now. Next thing to do is Brake and Power Steering Fluid. Gavin 2005 Range Rover Vogue SE 4.2 Supercharged V8 Follow my 4.2 Supercharged antics - https://www.fullfatrr.com/forum/topic63354.html https://www.instagram.com/l322_supercharged/ https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg https://www.youtube.com/@ChallengingClassics |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3192 ![]() ![]() ![]() |
The sump plug drain on these is a nightmare. Whoever thought it was a good idea to put it on the side so it goes everywhere should be shot! |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2276 ![]() ![]() ![]() |
Interesting mine is on just shy of 230k and I have never changed the oil in the supercharger maybe I should |
Now the weather is getting better I've started to look at a few little jobs that need doing. Over the weekend I replaced the 3rd brake light as my original was split, not seated properly and letting in water. Not ideal with the amount of rain we have had lately.
2005 Range Rover Vogue SE 4.2 Supercharged V8 Follow my 4.2 Supercharged antics - https://www.fullfatrr.com/forum/topic63354.html https://www.instagram.com/l322_supercharged/ https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg https://www.youtube.com/@ChallengingClassics Last edited by Superspoons on 29th Mar 2023 3:14pm. Edited 1 time in total |
Whilst I was up working around the tailgate I decided to remove the tailgate hinges, one at a time, and clean/seal the brackets where they meet the body. I had about 2in of water in the boot a few weeks ago and it needed sorting out.
Clean up around and under old hinge - Sealant in place and hinge bolted down -
