![]() | Home > Technical (L322) > Auto Wipers |
hi matt, is yours all up and working now... V8 facelift Range Rover Autobiography 22" wheels.
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1749 ![]() ![]() ![]() |
Hi Dave - I assume you mean new black trims down the left and right of the screen on the outside.? NO....
well yes as they have to stick to the windscreen down the front edge to stop wind noise, unless they put sealer on them, how about the top trim |
No unfortunately not - Was at work. Wish I had been now though.! Ash
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
my LCM 4 arrived yesterday and had a go at fitting but my faultmate had an issue programming the brand new unit so i am just waiting for blackbox to sort the issue out Matt |
stevenA Member Since: 23 Jan 2011 Location: Paris, France Posts: 34 ![]() ![]() |
Will be interested to hear if Blackbox find a solution to programming your LCM - I read somewhere else that this was a big problem (although cannot remember where) - particularly if you manage to avoid the dreaded black spot!
OK - Update
Thanks for the update Comports - you definately have my attention!
Managed to pop down to my mate this morning...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
my xenons dont do a level check on startup ash.. |
Thanks Mate... I may be ok then but will watch and see as I believe xenon's self leveling will form part of MOT soon.? Ash
There is no self level check on our lights, the adaptive ones do check though - up/down left/right.
hi ash, i have a bi-xenon headlight with the adaptive built in as a spare light, they will not work on our cars, the need some commands from other modules and the steering sensor as well, on the later cars 06 and on they started fitting them and yes when you start they go up and down only.. thats interesting info you man found, i am sure you have said but what diag system does he use. i was told that on the LCM it was a code once only unit making it impossible to write to it again...but theres no such thing as impossible. V8 facelift Range Rover Autobiography 22" wheels.
Hi Dave - He used his AutoLogic system today to re programme it all. My car was showing up as a petrol as well for some reason so he went through a few bits. Turned on daylight running but I didn't like that so we turned that off again. Ash
