Home > Technical (L322) > Auto Wipers |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi matt, is yours all up and working now... V8 facelift Range Rover Autobiography 22" wheels.
25th May 2011 7:03am |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
Hi Dave - I assume you mean new black trims down the left and right of the screen on the outside.? NO....
25th May 2011 7:28am |
well yes as they have to stick to the windscreen down the front edge to stop wind noise, unless they put sealer on them, how about the top trim was you there when they done it.. V8 facelift Range Rover Autobiography 22" wheels.
25th May 2011 7:56am |
No unfortunately not - Was at work. Wish I had been now though.! Ash
25th May 2011 7:57am |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
my LCM 4 arrived yesterday and had a go at fitting but my faultmate had an issue programming the brand new unit so i am just waiting for blackbox to sort the issue out Matt |
25th May 2011 9:24am |
stevenA Member Since: 23 Jan 2011 Location: Paris, France Posts: 34 |
Will be interested to hear if Blackbox find a solution to programming your LCM - I read somewhere else that this was a big problem (although cannot remember where) - particularly if you manage to avoid the dreaded black spot!
25th May 2011 12:57pm |
OK - Update
26th May 2011 1:08pm |
Thanks for the update Comports - you definately have my attention!
26th May 2011 9:07pm |
Managed to pop down to my mate this morning...
27th May 2011 10:53am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
my xenons dont do a level check on startup ash.. |
27th May 2011 11:11am |
Thanks Mate... I may be ok then but will watch and see as I believe xenon's self leveling will form part of MOT soon.? Ash
27th May 2011 11:15am |
There is no self level check on our lights, the adaptive ones do check though - up/down left/right.
27th May 2011 11:41am |
hi ash, i have a bi-xenon headlight with the adaptive built in as a spare light, they will not work on our cars, the need some commands from other modules and the steering sensor as well, on the later cars 06 and on they started fitting them and yes when you start they go up and down only.. thats interesting info you man found, i am sure you have said but what diag system does he use. i was told that on the LCM it was a code once only unit making it impossible to write to it again...but theres no such thing as impossible. V8 facelift Range Rover Autobiography 22" wheels.
27th May 2011 4:13pm |
Hi Dave - He used his AutoLogic system today to re programme it all. My car was showing up as a petrol as well for some reason so he went through a few bits. Turned on daylight running but I didn't like that so we turned that off again. Ash
27th May 2011 5:48pm |
