Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 33 of 38 <123 ... 323334 ... 363738>
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Cheers for the reply is this what I need BS611 8.73mm Bore, 1.78mm Section, Viton O Ring
Cheers Jay Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #658613 6th Mar 2023 10:55am
jaysta10k
Hi guys really have hit a brick wall STILL having smoke and horrible fumes which is ONLY intermittent mainly when car hot but that said did a 300 miles roundtrip recently and nothing no smoke or fumes etc... had 2 garages look at it don't know where its coimg from oil cooler done all good o ring on pipe done at back of oil cooler and I been monitering there's no oil on floor driveway etc! surely this oil wouldn't take 4 weeks to burn away from back of engine doesn't it only smoke as the oil hits the exhaust as this gets hot? Any other ideas what's causing these disgusting fumes and smoke at back of engine. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #659544 16th Mar 2023 11:32am
JayGee
It could still be residual oil from the original leak. 2012 TDV8 Vogue (L322)
Post #659548 16th Mar 2023 12:50pm
cass
@jaysta10k - When you had the cooler replaced did you fit a JLR part or a budget part?
The bloke who fitted mine said he would have refused the job if I'd wanted a cheaper version fitted as he's had several problems with them failing very quickly.
Post #659553 16th Mar 2023 2:46pm
jaysta10k
Hi it was aftermarket but area is all clear no leaks from the cooler etc.. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #659558 16th Mar 2023 3:16pm
Gowsh
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Ipanema Sand
@jaysta10k
I've been exactly where you are with the smoke fumes, I've changed every seal and gasket going in the cooler stack. Thought I'd cured it, no leaks at all, really clean, but the smell came back. Last night I spent a long time with a borascope searching for oil and found that the rear two of the four boost hoses from the dohnut had oil underneath, I fitted new ones last year so they are in good nick but I think I've been under tightening them just enough to allow a slight misting of oil to escape (at high boost) on to the hot engine.
Tightened them as much as possible, cleaned around them and took it out and got it really hot and didn't get the smell. Only one test so far but fingers crossed.
Post #661873 14th Apr 2023 1:12pm
jaysta10k
Hi @gowsh cheers for this info we have replaced the o rings on the turbo feed pipe into the back of oil cooler a few days ago with the Viton o rings the back of pipe etc seemed dry to be fair so it’s a process of elimination but very frustrating as everything pointed towards oil cooler. I will keep an eye on this next week or so and if smell and smoke is still present we will take a look at what you have suggested.
Cheers
J Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #661889 14th Apr 2023 2:55pm
pcourtney
Gowsh wrote:
@jaysta10k
found that the rear two of the four boost hoses from the dohnut had oil underneath, tightened them as much as possible, cleaned around them and took it out and got it really hot and didn't get the smell. Only one test so far but fingers crossed.
just tightened mine up, as I had a mist of oil under mine as well - let's see if that does cure it - fingers crossed !
Post #661890 14th Apr 2023 3:01pm
jaysta10k
Any chance of a picture of which to tighten up please.
Cheers
Previous Cars
BMW M3 Carbon Black
Post #661959 15th Apr 2023 2:35pm
Gowsh
Hi, it's the jubilee clips on the short hoses, there's 4 of them. Feel under the hoses first to see if thers oil there, also if they are original they may be split and tightening won't help.
Post #661977 15th Apr 2023 7:13pm
Gowsh
Post #661978 15th Apr 2023 7:16pm
jaysta10k
Hi thanks for this @gowsh thanks for this checked all jubilee clips checked all hoses no oil this is a mystery I think the only way to find out where the hell the intermittent smoke and fumes are coming from is for the car body to come off! We have explored all avenues there is one more thing to check a mechanic said he noticed a small amount of oil around turbo area so possible turbo oil leak maybe causing smoke fumes etc when hot. Any. more info from anybody else would be much appreciated.
cheers
Previous Cars
BMW M3 Carbon Black
Post #662432 21st Apr 2023 9:18am
Smoggie35
Right guys. Looking for inspiration on this topic from you Guru’s😜.
I still have a very tiny oil leak ( small patch on the drive) although I’m not having to top up the oil as it still states ‘Full’ when checked. This has been like this for over 2 months now!!
I have changed the 2 x turbo seals at the back of the cooler, both cooler gaskets which were very brittle and cleaned the engine as best I could, checked the doughnut hoses( tight and intact) and even bought a borescope to see if the casing is cracked when hot but cannot find any trace of where it’s coming from.
I’ve had the wind deflector ( underneath) off the engine section and cleared around here. Nothing at the oil plug incidentally and nothing of note here. Just a path the oil could have taken coming from the top are of the engine. There was/ is a slight build up around the bell housing so could it be the crank seal that’s passing? Hope not as that’s something I won’t be undertaking myself.
I’m stumped now but would like to get to the bottom of it.
Anyone got any other ideas please??
Post #664696 22nd May 2023 2:24pm
JayGee
Are you sure it's engine oil? I had a gearbox leak on the pan seal 2012 TDV8 Vogue (L322)
Post #664699 22nd May 2023 2:47pm
Smoggie35
Looks like engine oil. Black in colour. Wouldn’t have thought the gearbox oil would be that colour. Haven’t checked the level as the leak looks like it’s coming further from the from the front as only the first wind deflector/ skid pan has oil on the inner surface.
I’ll check all the same so thanks for the heads up.
Post #664707 22nd May 2023 4:05pm
