Home > My Range Rover > Back with another Supercharged
Page 55 of 58 <123 ... 5455 565758>
conor
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Hello David!
Remember me!?
Just caught up on your thread here.. i'm in awe of the amount of work you have done with your SC. I put mine off the road in November. It has a leaking oil cooler line which I admittedly badly repaired..and it needs a new ball joint.
I have a lot of other bits going on at the moment so the RR probably won't see work this year..
I do often wonder what I will do with the SC as whenever I drive it I get a bit peeved at the crap fuel economy... that said i'd love to get it back to it's former glory and have it for the odd jaunt here and there. Your wheels are still sitting there, untouched LMAO. (07) 2007 3.6 TDV8 L322 - 135k miles.
(05) 2006 MY Supercharged L322 - Zambezi Silver on Jet Black - 162k miles.
** Smiles per gallon - never forget **
Post #654327 22nd Jan 2023 3:34am
dhallworth
Hi Conor, long time no speak! I reckon mine is averaging 11mpg or 50p a mile in fuel at the moment so it’s definitely a car you’ve got to want to drive Very Happy
Must admit, I read this thread from start to finish a few days ago and there’s a lot of work I’ve done that I’d totally forgotten about Laughing I really hope the wife never finds this thread! Rolling with laughter
We had friends visit today so I didn’t get out to the workshop until gone 5.
I removed the rear wheel and had the arch liner off in 10 mins and then proceeded to remove the solenoid from the Petrol return. Pictures taken with the electronic part of the solenoid removed.
For quickness and to test my theory of this being the cause of my problems I’ve blocked both ends of the solenoid with chemical metal and have used a bolt that’s a very tight fit in the pipe on both sides as well.
I’m just giving the chemical metal some time to cure properly before reassembling this evening.
Once it’s reassembled I’ll have a look with the IID tool and see what the fuel pressure looks like. If it’s stable and this has cured the problem I’ll wait until the summer comes and the temperatures have improved and I’ll look to drop the covers and remove the tee from the pipe under the car or even replace the pipe that was cut.
I’ve gone to so much effort to remove the LPG, I might as well make sure there’s no signs it was ever there.
Post #654387 22nd Jan 2023 8:49pm
dhallworth
Car sat overnight and this morning fired into life instantly at the flick of the key. Looks like that has indeed been the cure and not the non return valve on the fuel pump.
Car felt like it was driving beautifully on the way home from getting the alignment checked this morning too.
Really hoping I’ve broken the back of the constant niggles now.
Post #654435 23rd Jan 2023 9:44am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
Lets hope so David Laughing 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #654547 24th Jan 2023 9:01am
dhallworth
I’m now 70 miles of mixed driving in and no warning lights so all good Smile
Had the alignment tweaked again yesterday morning as I wasn’t happy and have to say it’s driving like a different car at the moment. Much more like my old one now. Smile
Post #654557 24th Jan 2023 10:33am
dhallworth
As of Friday evening the RR has covered 400 miles with the new sensors, and the fuel return sorted.
I'm pleased to say that we've got no fault codes stored and the cars feels better to drive then it did before too.
The 400 miles has included some long distance for work including a couple of days commuting from the hotel to the office in stop/start traffic so I'm fairly confident I'd have seen the light back on by now if it was going to.
Fingers crossed this continues for a bit!
Post #655146 30th Jan 2023 3:44pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Good to hear its all getting there mate. Certainly taken up plenty of time
Allen
Post #655147 30th Jan 2023 4:03pm
Superspoons
Good to hear the beast is back to its best again David Thumbs Up - mines undergoing surgery this week for it coolant loss.. Big Cry Gavin
https://www.youtube.com/@ChallengingClassics
Post #655169 30th Jan 2023 7:13pm
dhallworth
Since changing the MAF, both oxygen sensors, sorting the vacuum leak and the fuel return issue, we're now 1000 miles in.
Car still starting instantly at the flick of a key so fuel return was definitely the issue, not the fuel pump as I first thought.
Engine management light has stayed off and fuel trims are showing nice and equal on diagnostics. Car is still driving nicely too Smile
So, since the engine rebuild, that's now 3000 miles on the clock, or, 10 x 100l tanks of petrol, and a ton of Shell Drivers Club points 🤣
Good job I didn't buy it thinking it'd be cheap to run!
Post #658169 1st Mar 2023 1:03pm
Superspoons
Good news David Thumbs Up
Reminder it 'smiles per miles' .... Gavin
Post #658174 1st Mar 2023 1:44pm
quavey
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
As I understand it there are 4 oxygen sensors, did you do both fronts? Both rears? Or All 4? 2005 E60 M5
2006 (MY07) L322 4.2 S/C
2024 i7 xDrive60
2004 L322 4.4 Vogue, 2002 L322 4.4 HSE, 2006 (MY07) L322 S/C , 2001 P38 Vogue, 1999 P38 4.6 HSE.
Post #658187 1st Mar 2023 5:16pm
dhallworth
I only changed the front 2.
The rear 2 only monitor the catalyst efficiency, it's the front 2 that monitor the emissions and alter the fuel ratio.
Well, that's my understanding of it anyway Smile
Post #658193 1st Mar 2023 6:14pm
Phoenix
And your understanding is correct - pleased you got all the wrinkles sorted and can get on with enjoying the fruits of your labours!
Post #658198 1st Mar 2023 7:05pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
That's my understanding as well, however i changed the post cat sensors as well because they age and I kept getting cat failure messages from one of them.
They are not expensive so it made sense to me to do them with the fronts.
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #658202 1st Mar 2023 8:13pm
quavey
David.
Thanks David, I still an issue on mine but I wonder if actually its the front sensor that is causing the issue. Beyond me though, it'll have to be a job for the garage. 2005 E60 M5
2024 i7 xDrive60
Post #658216 1st Mar 2023 10:12pm
