![]() | Home > My Range Rover > Back with another Supercharged |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3179 ![]() ![]() ![]() |
Hi Conor, long time no speak! I reckon mine is averaging 11mpg or 50p a mile in fuel at the moment so it’s definitely a car you’ve got to want to drive |
Car sat overnight and this morning fired into life instantly at the flick of the key. Looks like that has indeed been the cure and not the non return valve on the fuel pump.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
Lets hope so David |
I’m now 70 miles of mixed driving in and no warning lights so all good |
As of Friday evening the RR has covered 400 miles with the new sensors, and the fuel return sorted.
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Good to hear its all getting there mate. Certainly taken up plenty of time
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 394 ![]() ![]() ![]() |
Good to hear the beast is back to its best again David |
Since changing the MAF, both oxygen sensors, sorting the vacuum leak and the fuel return issue, we're now 1000 miles in.
Good news David |
quavey Member Since: 22 Jan 2017 Location: Lancaster Posts: 304 ![]() ![]() ![]() |
As I understand it there are 4 oxygen sensors, did you do both fronts? Both rears? Or All 4? 2005 E60 M5
I only changed the front 2.
And your understanding is correct - pleased you got all the wrinkles sorted and can get on with enjoying the fruits of your labours! |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 606 ![]() ![]() ![]() |
That's my understanding as well, however i changed the post cat sensors as well because they age and I kept getting cat failure messages from one of them.
Thanks David, I still an issue on mine but I wonder if actually its the front sensor that is causing the issue. Beyond me though, it'll have to be a job for the garage. 2005 E60 M5 2006 (MY07) L322 4.2 S/C 2024 i7 xDrive60 -------- 2004 L322 4.4 Vogue, 2002 L322 4.4 HSE, 2006 (MY07) L322 S/C , 2001 P38 Vogue, 1999 P38 4.6 HSE. |
