Home > Technical (L322) > Parking Heater Remote Control
Page 3 of 7 <1234567>
dan_uk_1984
What a load of bull! Webasto even provide an official retrofit kit for any vehicle with a FBH.
Can you verify what model reciever you have? 3 10mm bolts and the mounting plate will spin round - you don't actually need to unplug anything.
Dan
Post #65589 24th May 2011 5:57pm
Avi
2006 Range Rover Vogue Td6 Alveston Red
The remote I bought is just a webasto one, no mention of land rover! Works fine.
Post #65590 24th May 2011 6:00pm
Dan
I was going to reply earlier but the car has been away sorting out some rust on the tail gate but any hoo,
I have a Wabasto T90 unit do you think that means I Need a T91 transmitter ?
On reflection sod it I'll PM Wiggs and hope and pray, I have a feeling that the new shape will still work. 2008 MY Supercharged
Post #65744 25th May 2011 5:10pm
dan_uk_1984
Like you I have the T90.
This guy says his remote is for the T90 or T91. This would suggest they are cross compatible.
http://cgi.ebay.co.uk/Webasto-VW-AUDI-T90-...0553545859
Post #65758 25th May 2011 5:49pm
Many thanks Dan Thumbs Up
The sale has ended but he states that the new designe has superseded the old so I'm even more confident that I can get one that works. 2008 MY Supercharged
Post #65760 25th May 2011 5:54pm
stu
sorry not had a chance to get the model number out of the boot yet, if the remotes are all compatiable what the hell am i doing wrong??
i have tried to follow the instructions and still nothing... Sad
i am waiting for a T90 remote to come in the post, i shall see if that works. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #65822 26th May 2011 4:39am
wiggs
You need to pull the fuse for at least 5 seconds
Replace fuse and within 5 seconds press the OFF
button on the transmitter for at least 1 second.
Post #65846 26th May 2011 11:20am
OK since we are now talking about pulling fuses this is where I'm now confused get it ? Confused any way,
is it fuse 14 in the rear fuse box marked Remote Handset ?
or fuse 14 front fuse box marked Auxiliary Heater ?
or indeed fuse 59 front fuse box marked Auxiliary Heater ?
many thanks in advance for any one who can tell me. 2008 MY Supercharged
Post #65854 26th May 2011 1:09pm
wiggs
Dunno about the FFRR ...but when i paired a D4 the other week it was fuse F2 in engine bay fuse box ....Diesel fuel burning heater .
Post #65866 26th May 2011 1:40pm
wiggs
Post #65867 26th May 2011 1:40pm
Thanks for that , in a round about sort of way It helps as I now have done more digging in search and it looks like fuse 59 FBH front fuse box.
Plan B is try and pull each fuse in tern ,that's about 1230 trial and error goes Shocked 2008 MY Supercharged
Post #65869 26th May 2011 1:54pm
Avi
Definitely Fuse 59 (Behind Glovebox). I've programmed several remotes to mine.
This would end in tears ! Big Cry
Post #65879 26th May 2011 2:40pm
stu
i have just been in the boot and undone the three bolts to see what module i have. it is a telestart T90.
is anyone using a T91 remote in conjunction with a T90 module??
or are the majority using the older type T90 remote still?? Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #65916 26th May 2011 5:17pm
T91 remote arrived this morning from Wiggs Thumbs Up and I have a T90 Telestart in the boot,
puled fuse 59 glove box fuse box waited 15 seconds and put fuse back, strait away pushed the off button on the T91 remote and one second latter the red light came on, jobs a good un.
Now if this is such a good feature and it appears all cars with park heating fitted have a telestart module fitted ,
How come so many Censored sell their cars without the remote ? Banging Head 2008 MY Supercharged
Post #66009 27th May 2011 10:51am
wiggs
Glad it all worked and was an easy job Very Happy
Post #66011 27th May 2011 11:00am
