Home > Technical (L322) > 4.4 tdV8 Starter motor investigation. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
I bought my replacement starter back in April because I got the dreaded click and wanted to get it changed whilst the weather was decent..... however seven months later it has never “clicked” again so the new one is still in the box.
23rd Oct 2019 4:42pm |
ozzy22 Member Since: 16 Oct 2019 Location: Glasgow Posts: 20 |
Thanks for the reply Mike.
24th Oct 2019 9:57am |
Hi All,
28th Oct 2019 9:40am |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 361 |
Ozzy a quick question did you raise the suspension, remove drivers wheel then lower the suspension to get the clearance on the anti roll bar? Presumably must still have battery connected to start engine to lower suspension?
8th Nov 2019 7:28pm |
Bolert Member Since: 29 Jun 2021 Location: Hythe, Kent Posts: 30 |
Massive thanks to Mpirie instructions, changed mine today on my 2012. All went well. Bit of fiddle but got it done. Put car in access mode before jacking it up which meant anti roll bar was in lowest position. Had no issues. Started on the button once all back together. See how it is in the cold weather and hopefully do another 100k! 2012 4.4 TDV8 AB Sumatara Black with Ivory / Jet interior |
11th Feb 2023 6:08pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
I had the dreaded click however i had other issues that soon followed that resulted in a new battery (Genuine LR one AGM) since i fitted that about 6months ago not happened since! 2012 Vogue 4.4 TDV8 - Current
11th Feb 2023 6:22pm |
Yes have read that also. When I bought the car 2 years ago I fitted a new AGM battery. Wasn't anything wrong but changed anyway as know old batteries can cause lots of issues. Turned out was the original one, had 9 years so worth changing.
11th Feb 2023 6:26pm |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
Get the starter mod done, it continues to work for me very well even with low SOC. The issue here is the trigger wire sensitivity/resistance change over a period of time. I have a secondary solenoid installed, but some have upgraded the wire.
19th Feb 2023 7:55pm |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 |
ffrr14
20th Feb 2023 9:27am |
Awesome, good idea. do you have details on items and 'how to' as Tom has asked? might be in the Wiki already will take a look... Thanks in advance. 2012 4.4 TDV8 AB Sumatara Black with Ivory / Jet interior |
20th Feb 2023 1:06pm |
21st Feb 2023 8:12pm |
DeeJay Member Since: 16 Oct 2021 Location: Western Cape Posts: 34 |
&t=452s This video nicely explains how to go about things with the solenoid contacts. 2011 Vogue SE 4.4 TDV8 |
26th Feb 2023 12:39pm |
Ive done three things (in this order) to greatly reduce the frequency with which clicking occurs...
26th Feb 2023 12:51pm |
Car wont start when hot used to happen with my car, but no more. Once you get the mod done you will be very happy with results, I am. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
27th Feb 2023 1:50pm |
