Home > Technical (L322) > 4.4 tdV8 Starter motor investigation.
Page 2 of 6 <123456>
ozzy22
Scotland 2012 Range Rover Vogue TDV8 Stornoway Grey
Hi,
I have just joined the club and have bought my first Range Rover. The second day I had it, I got the dreaded click. I've bought a new starter and am debating if I fit it or get the shop to. Mike, how did you go with the fitting of yours?
Thanks in advance if anyone has tips.
Post #531925 23rd Oct 2019 5:28pm
Baltic Blue
I bought my replacement starter back in April because I got the dreaded click and wanted to get it changed whilst the weather was decent..... however seven months later it has never “clicked” again so the new one is still in the box.
Sod’s law says it will fail now winter is approaching, but a friend has offered me the use of his workshop/large garage when I eventually need to change it.
Post #531926 23rd Oct 2019 5:42pm
ozzy22
Thanks for the reply Mike.
I think I will try and give it a crack this weekend as I'm planning to do a bit of driving through the Highlands this winter and dont want to get stuck. It seems to do it much less if I push and hold the starter button until it is running. No doubt Ill be referring to Mpirie's guide that he has posted.
Post #531969 24th Oct 2019 10:57am
ozzy22
Hi All,
HELP.....
So I installed the new starter motor yesterday. Re-connected all the wires and cleaned all the contacts. Pushed the start button and got nothing. Didn’t even sound like it was trying to engage. Couldn’t hear a big click like from solenoid or anything. Checked all connections again and still nothing. So I pulled the new starter back out and installed the old. I got the solenoid click twice but then it started.
Mpirie instructions are perfect and made the job much easier.
I then connected the new starter to the battery with jumper leads and got it to spin up no problems........ slightly stumped as to what is going on.
Any help would be greatly appreciated!
I guess the only upside is that I’m getting good at getting the starter out and back in Very Happy
Post #532406 28th Oct 2019 10:40am
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Ozzy a quick question did you raise the suspension, remove drivers wheel then lower the suspension to get the clearance on the anti roll bar? Presumably must still have battery connected to start engine to lower suspension?
Thanks
Richard 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #533558 8th Nov 2019 8:28pm
Bolert
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Massive thanks to Mpirie instructions, changed mine today on my 2012. All went well. Bit of fiddle but got it done. Put car in access mode before jacking it up which meant anti roll bar was in lowest position. Had no issues. Started on the button once all back together. See how it is in the cold weather and hopefully do another 100k! 2012 4.4 TDV8 AB Sumatara Black with Ivory / Jet interior
Post #656298 11th Feb 2023 7:08pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
I had the dreaded click however i had other issues that soon followed that resulted in a new battery (Genuine LR one AGM) since i fitted that about 6months ago not happened since! 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #656300 11th Feb 2023 7:22pm
Bolert
Yes have read that also. When I bought the car 2 years ago I fitted a new AGM battery. Wasn't anything wrong but changed anyway as know old batteries can cause lots of issues. Turned out was the original one, had 9 years so worth changing.
Glad you got yours sorted 2012 4.4 TDV8 AB Sumatara Black with Ivory / Jet interior
Post #656301 11th Feb 2023 7:26pm
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
Get the starter mod done, it continues to work for me very well even with low SOC. The issue here is the trigger wire sensitivity/resistance change over a period of time. I have a secondary solenoid installed, but some have upgraded the wire.
 SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #657158 19th Feb 2023 8:55pm
TomCobbly
ffrr14
I'm very interested in the starter mod you mention, is there a link to how it is done? If not then a link to the wire upgrade please. 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #657192 20th Feb 2023 10:27am
Bolert
Awesome, good idea. do you have details on items and 'how to' as Tom has asked? might be in the Wiki already will take a look... Thanks in advance. 2012 4.4 TDV8 AB Sumatara Black with Ivory / Jet interior
Post #657211 20th Feb 2023 2:06pm
ffrr14
Essentially I have spliced into the current trigger wire very close to the EJB (picture 4) to drive a smaller relay that supplies / services the starter relay solenoid directly from the battery.
Edit: I have added a Autoreset Circuit Breaker 40A on head end SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #657393 21st Feb 2023 9:12pm
DeeJay
South Africa 2011 Range Rover Vogue SE TDV8 Fuji White
Re: 4.4 tdV8 Starter motor investigation.
Baltic Blue wrote:
high resistance / burned/ tarnished contacts in the solenoid section of the starter motor.
&t=452s
This video nicely explains how to go about things with the solenoid contacts. 2011 Vogue SE 4.4 TDV8
Post #657850 26th Feb 2023 1:39pm
DeeJay
Ive done three things (in this order) to greatly reduce the frequency with which clicking occurs...
1) Replaced the battery
2) Replaced the solenoid on the starter motor
3) Upgraded the battery
And then a fourth
4) Try a few things......... This has reduced the instances of click-click the most!
- Deployable side steps switched off.
- Aircon switched off before switching off the car (so its not on when starting).
- With each startup make sure the Press Brake warning sign goes away as Im pressing the brake to make sure my foot is on it deep enough
...and then start.
With all these things I find now the only reason the car would give me the click-nonsense is if it is really hot - like ive driven it the whole day, then stop somewhere, then restart to go another bit. And even that is not a pattern.
...........but its never left me stranded Laughing 2011 Vogue SE 4.4 TDV8
Post #657856 26th Feb 2023 1:51pm
ffrr14
Car wont start when hot used to happen with my car, but no more. Once you get the mod done you will be very happy with results, I am. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #657970 27th Feb 2023 2:50pm
