Home > Maintenance & Mods (L322) > 2008 TDV8 Key Battery
WDRR
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
Hi everyone does anyone know of hand what battery is used in the key fob. I should know I took the key apart a few weeks ago and spent 10 mins getting it back together. I will pull it apart again if required but i've also found its best to open these things up as few times as possible or perhaps I am just to cautious.
Post #656976 17th Feb 2023 8:13pm
WDRR
Found it all, Its a CR2032
Post #656977 17th Feb 2023 8:16pm
dhallworth
The cell in a 2008 flip key isn’t a 2032. It’s a rechargeable battery that’s soldered onto the board.
It’s a VL2330 from memory.
Post #656985 17th Feb 2023 9:24pm
dhallworth
Update - here’s the link to the kit I bought to refurbish mine.
https://www.ebay.co.uk/itm/253381274834?mk...media=COPY
The battery is a sod to get off the board as it needs to be unclipped and unsoldered at the same time.
Post #656986 17th Feb 2023 9:25pm
WDRR
Apologies all. The key I have with the car is an after market key. Although I looked up the so called battery on EBAY. sorry not your link @dhallwork my own detective work ! I have just stripped the key and found a CR1632 inside not the EBAY solution. I have recently purchased the car, I will replace the battery and see how long it lasts. I need to buy a second key anyway...... Any suggestions? where to buy. I understand the OEM keys are quite expensive.
Post #657008 17th Feb 2023 11:54pm
WDRR
BTW the battery is not soldered to the board on this one and there is a kill switch under the steering wheel which appears to disable the alarm .... thats on the delete mod list Shocked
Post #657010 17th Feb 2023 11:59pm
WDRR
Thanks @dhalworth for the info on the Ebay link. I need a full new key although I have an original fob with no key stock. In fact I haven't opened that one.... it works... I need to think this through all...Anyone know where `i will get a key shaft cut?I will keep you posted on a solution. I now know someone who may know ....
Post #657013 18th Feb 2023 12:09am
Weegie
My 2008 Tdv8 key battery is induction charged via the ignition switch. Would yours be the same? John
GAP iiD BT-Sold
Post #657027 18th Feb 2023 9:29am
WDRR
Hi all. update on the key front. Note I have just purchased the car and I am still learning about it.
I enclose pictures of both keys I have stripped down.
One key is an original with an original battery and board and a dodgy broken blade. This remote works and you can access the
and unlock the door but you cant start the engine with it. Note the blade is broken and a half a***d attempt at a copy has been made.
The second keys is a replacement from someone, It has the same shell but a smaller board and a CR1632 battery. The blade works and it starts the engine. The remote works but I replaced battery about three weeks ago and it is already about to give up !
Short term solution I have moved the original board and battery into the new shell and blade. I will get an other CR1632 short term as backup.
I have been looking on line and I can easily find the shell and battery and I think board but I am struggling to find the right blade to copy. The blades shown on line seem to be to fit a Range Rover Sport and from looking at them they are slightly tapered rather than fully straight. I don't know if that will make much difference?
I will keep looking and update if I find a proper reasonable solution.
Cheers
 Willie
2008 TDV8 Santorini Black
Post #657061 18th Feb 2023 2:15pm
WDRR
The short answer is I don't know, hopefully. I will use the original board / battery and see if I have any more issues. Thanks for the info Thumbs Up Willie
Post #657062 18th Feb 2023 2:19pm
dhallworth
Make sure and only fit a Duracell battery to the key as others makes on my other car keys don’t seem to last.
Post #657070 18th Feb 2023 3:51pm
WDRR
will do David Thumbs Up Willie
Post #657077 18th Feb 2023 6:46pm
