![]() | Home > Maintenance & Mods (L322) > 2008 TDV8 Key Battery |
WDRR Member Since: 12 Feb 2023 Location: Glasgow Posts: 27 ![]() ![]() ![]() |
Found it all, Its a CR2032 |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3143 ![]() ![]() ![]() |
The cell in a 2008 flip key isn’t a 2032. It’s a rechargeable battery that’s soldered onto the board.
Update - here’s the link to the kit I bought to refurbish mine.
Apologies all. The key I have with the car is an after market key. Although I looked up the so called battery on EBAY. sorry not your link @dhallwork my own detective work ! I have just stripped the key and found a CR1632 inside not the EBAY solution. I have recently purchased the car, I will replace the battery and see how long it lasts. I need to buy a second key anyway...... Any suggestions? where to buy. I understand the OEM keys are quite expensive. |
BTW the battery is not soldered to the board on this one and there is a kill switch under the steering wheel which appears to disable the alarm .... thats on the delete mod list |
Thanks @dhalworth for the info on the Ebay link. I need a full new key although I have an original fob with no key stock. In fact I haven't opened that one.... it works... I need to think this through all...Anyone know where `i will get a key shaft cut?I will keep you posted on a solution. I now know someone who may know .... |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3243 ![]() ![]() ![]() |
My 2008 Tdv8 key battery is induction charged via the ignition switch. Would yours be the same? John
The short answer is I don't know, hopefully. I will use the original board / battery and see if I have any more issues. Thanks for the info ![]() 2008 TDV8 Santorini Black |
Make sure and only fit a Duracell battery to the key as others makes on my other car keys don’t seem to last.
will do David |
