Home > Maintenance & Mods (L322) > 2008 TDV8 Key Battery |
WDRR Member Since: 12 Feb 2023 Location: Glasgow Posts: 27 |
Found it all, Its a CR2032 |
17th Feb 2023 8:16pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3030 |
The cell in a 2008 flip key isn’t a 2032. It’s a rechargeable battery that’s soldered onto the board.
17th Feb 2023 9:24pm |
Update - here’s the link to the kit I bought to refurbish mine.
17th Feb 2023 9:25pm |
Apologies all. The key I have with the car is an after market key. Although I looked up the so called battery on EBAY. sorry not your link @dhallwork my own detective work ! I have just stripped the key and found a CR1632 inside not the EBAY solution. I have recently purchased the car, I will replace the battery and see how long it lasts. I need to buy a second key anyway...... Any suggestions? where to buy. I understand the OEM keys are quite expensive. |
17th Feb 2023 11:54pm |
BTW the battery is not soldered to the board on this one and there is a kill switch under the steering wheel which appears to disable the alarm .... thats on the delete mod list |
17th Feb 2023 11:59pm |
Thanks @dhalworth for the info on the Ebay link. I need a full new key although I have an original fob with no key stock. In fact I haven't opened that one.... it works... I need to think this through all...Anyone know where `i will get a key shaft cut?I will keep you posted on a solution. I now know someone who may know .... |
18th Feb 2023 12:09am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3217 |
My 2008 Tdv8 key battery is induction charged via the ignition switch. Would yours be the same? John
18th Feb 2023 9:29am |
18th Feb 2023 2:15pm |
The short answer is I don't know, hopefully. I will use the original board / battery and see if I have any more issues. Thanks for the info Willie 2008 TDV8 Santorini Black |
18th Feb 2023 2:19pm |
Make sure and only fit a Duracell battery to the key as others makes on my other car keys don’t seem to last.
18th Feb 2023 3:51pm |
will do David Willie
18th Feb 2023 6:46pm |
