Home > Technical (L405) > 3.0 TDV6 Crankshaft issue |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1422 |
Please enlighten us, so this is not just heresay that JLR have made no changes to the V6 bearing retention architecture whatsoever, where is this documented? (“No, it has not been resolved.”) I am also a mechanical engineer by profession, and I would very much like to see documented proof and statistics, not just unsubstantiated opinion. This proposed evidence could be used in a class action against JLR, perhaps it is time for this, if those who have the evidence will come forward, and the numbers of vehicles are substantial enough? “If it ain’t broke, don’t fix it” -where’s the fun in that? |
30th Jan 2023 11:02pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2474 |
A person who rebuilt his 3.0 D4 engine after the crankshaft broke posted pictures of the new genuine LR crankshaft beside the original. At least some of the bearing oil holes were obviously in different places on the new crankshaft, particuarly noted in the main bearing adjacent to the break where it was possibly 90 deg different. This showed that the crankshaft design and or finishing has indeed changed, possibly when the reported Ford updated crankshaft design was produced before Ford Australia would use the 2.7 in the locally produced Territory or possibly before Ford USA would use the the 3.0 engine in its trucks, albeit with at least different inlet manifolds. The Ford revised 3.0 crankshafts were reportedly then fitted to the 3.0 engines that Ford was supplying LR for its varous vehicles.
31st Jan 2023 4:49am |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
Who said improvements to the bearing retention design has not changed whatsoever? Of course it has changed with the introduction of tabbed bearings. Kev 2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
31st Jan 2023 6:34am |
Er, that bit? I didn’t mean to be rude or start an argument, -I was only asking the question: where oh where is the written evidence with dates, VIN.numbers etc? Or, isn’t there any? Otherwise it all becomes a bit like, “A guy at the pub told me that……” “If it ain’t broke, don’t fix it” -where’s the fun in that? |
31st Jan 2023 8:46pm |
I think you need to go back, read and understand the context. For a start, the context of my post concerned the crank webs, not how the bearings are held in place and fundamental does not mean 'no design change whatsoever'
31st Jan 2023 8:59pm |
Two prime examples above of peeps saying one thing and meaning another, not explaining things in clear & concise English, we are not clairvoyant and can only read the written words, not the unwritten ones.
31st Jan 2023 9:17pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2564 |
There’s a suggestion that the US version of the engine (for the F150 and now the new Ranger/Amarok, and also made in Dagenham) has a revised bottom end. |
31st Jan 2023 9:19pm |
I really don't see how much clearer I could have been... The main issue is down the fundamental design of the bottom end to support a transverse mounting arrangement for installation into the Citroën C5, Citroën C6 and Peugeot 407. This leaves the crank web or cheek to contain less mass than what would typically be present in a robust design. Kev 2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
31st Jan 2023 9:27pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1751 |
JLR wanted the whole engine to be 2" longer due to concerns about the crank
1st Feb 2023 7:40am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 731 |
Many thanks to all those who have responded with relevant information, I have a much clearer view of the issue now and as the dust should have settled from the agitators trying to pick a fight in defence of the TDV6 can we return to the topic of my first post?
1st Feb 2023 12:09pm |
Yes it does still happen unfortunately Cass. It's worth noting that not all cranks give way are as a result of spun bearings. Whilst the redesigned bearing retention method was a great control to implement, it is a little bit of a red herring w.r.t. crank fractures.
1st Feb 2023 2:26pm |
Thanks Kev
1st Feb 2023 4:03pm |
Give Joe Short a call at Oval Autos. He knows the engines inside out and he rebuilds the TDV6s on a daily basis, along with some enhancements to give them the best chance of survival post-rebuild. He'll be able to give you an expert opinion based on the numbers he gets through his doors based on model year. He's very approachable. Tell him I sent you. Kev
1st Feb 2023 4:30pm |
Coincidentally, the following video has been posted by LR Time today. If you skip to around 16 minutes, this is discussed. Worth a watch if anyone is interested. Kev 2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
5th Feb 2023 9:41pm |
