Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
LandyManSam Member Since: 10 Jul 2019 Location: Wild West Ireland Posts: 51 |
Hi all, been a while since I've been on here - but was really pleasantly surprised that this topic has been active with some really interesting work done
23rd Jan 2023 2:09pm |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 453 |
I changed the CVD module and it made no difference at all. I then had the rear alignment done and it seemed to cure it, even though I marked everything when I changed the rear arms, they must be different dimensions as the rear toe was miles out. the 4 wheel alignment seemed to make the car drive so much better. Christian. Current Cars 2011 Range Rover Vogue SE 2020 BMW M4 Competition 2019 BMW X4 My RR Blog: www.facebook.com/L322Project or https://www.fullfatrr.com/forum/topic61540.html |
23rd Jan 2023 2:24pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 |
Hi,
23rd Jan 2023 2:32pm |
Interesting that alignment could have a significant effect on ride quality. I have a full set of rear arm bushes to swap in when I get a chance - which will be followed by a full alignment.
23rd Jan 2023 3:37pm |
Sorry, might have misled a bit there, the height sensor had more of an effect than anything else. Lower arms helped sharper steering. Mentioned the other bits as I can’t get tracking and suspension heights calibrated till CV replaced, then I’m hoping might be a bitter better still. 2011 Range Rover Vogue SE 4.4 TDV8
23rd Jan 2023 3:47pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
I still say tyres are the main determining factor for how comfortable a car rides over rough road surfaces. 2012 TDV8 Vogue (L322) |
23rd Jan 2023 4:24pm |
Ah sorry was referring to Caesium's post about his alignment curing his issue. Fingers crossed for yours! Sam's Motor & Machine YouTube Channel: https://www.youtube.com/channel/UCgNSRjY0I9FCzsi9ku3ccbw Home of the 'Cheapest 4.4 TDV8 Range Rover" |
23rd Jan 2023 4:31pm |
When I had the front upper and lower arms done + 4 wheel alignment the ride got a bit firmer (Less give in the bushings) but the handling got sharper and I was happy with that compromise. 2012 TDV8 Vogue (L322) |
23rd Jan 2023 4:39pm |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 692 |
Any progress on this Landymansam?
20th Apr 2023 7:14pm |
Privanthe Member Since: 18 Apr 2021 Location: Linlithgow Posts: 63 |
Just wanted to add something on to this thread as I wasn’t aware until now. Have been talking with Patrick @ IID - I wanted finer details on the calibration process and how best to do it, terrain/speed etc.
28th Jun 2023 6:37pm |
A few weeks back I pulled the fuse for the CVD system overnight and was pretty convinced the car was softer riding the next day. Mine's not especial harsh to start with but still.... 2012 TDV8 Vogue (L322) |
29th Jun 2023 7:21am |
Just had a look in the IID tool manual Privanthe and yes, it's only intended for fitment of a new module, it was in the manual all along...
29th Jun 2023 7:46am |
Pic that should have been with my previous post.
colalowe Member Since: 11 Jul 2021 Location: Lancashire Posts: 106 |
Hi all,
29th Jun 2023 2:57pm |
