![]() | Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
That explains how the dampers go from firm to soft but not how the ECU decides when to set the dampers to firm or soft. Early RR drivers no doubt expected a soft ride with relaxed handling but the market shifted to customers who wanted a firmer more responsive ride and this may be the compromise we have now. I still can't see how a system like this can at once detect a sudden jolt from an imperfection in the road surface and open the shock absorber valve quickly enough to prevent it causing that motion to be transferred to the body. 2012 TDV8 Vogue (L322) |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
They are just external reservoirs to hold more oil. They can get knocked and break off which allows all the oil in the shock to drain out. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8521 ![]() ![]() ![]() |
Electricity travels at roughly 90% of the speed of light, easily fast enough for the dampers to adjust in real time to suit the road conditions... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
The ECU still has to receive and process the signals from the accelerometers and height sensors and then the valve has to open which is a mechanical device. Unless there was a sensor system that read the road infront of the vehicle to soften the dampers ready for an impact I can't see how this can work to iron out these kinds of jolts. 2012 TDV8 Vogue (L322) |
I recall reading that Mercedes scan the road so that the shocks can be prep'd for the bump, rather than wait for the sharp wheel movement when its a bit late. |
Maybe it responds to the pothole by tightening up and preventing bounce once you have driven over it...
Mine's much better now. I had been running on -12mm via the GAP IID tool and reset it to standard and it suddenly got a lot better. Doubt a 12mm change in itself made a difference but it may well have reset something? 2012 TDV8 Vogue (L322) |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
I have noticed that my car has also gotten quite hard at the rear end and I have metered out the dampers for PWM directly by interfacing my multimeter with the damper wiring. I set the meter up for data logging and got some direct data from the drive around the block.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 900 ![]() ![]() ![]() |
Graeme wrote this back in Nov 2017 - which caught my eye
I calibrated mine whilst stationary and they are still race car hard so I'm not sure that has any relevance to the fault I am seeing.
Logically such a system would self calibrate over time to account for long term changes like wear in shock absorbers and short term changes like load changes i.e when the vehicle is fully loaded and when it's not. 2012 TDV8 Vogue (L322) |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Interesting… I assume all you did was follow the guided height calibration? No other steps? Did you check your height sensors were not rusted? Mine were… and maybe that extra 12mm is enough for it to move around… if starting to seize. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
I’ve always calibrated on the move. I thought it only worked when moving, so will try tonight. Just to see if it makes a difference… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
I am keen to see how you get on. I purchased a CVD module a while back, but it turned out to be from an l320 so not compatible. My rears seem harsher than the fronts, despite new rear struts. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
