Home > Maintenance & Mods (L405) > Importance of regular servicing!! |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1205 |
18th Jan 2023 10:33pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1195 |
Yep every 3 months for me. I guess there a few owners who ignore the app or the dash service notification.
19th Jan 2023 5:54pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
WOWSERS!!! Not seen one that bad before...
19th Jan 2023 10:57pm |
My top tip to get as much old oil out as possible is;
20th Jan 2023 3:19am |
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 281 |
Basil, I told you not to use O’Reilly! 2016 SDV8 AB |
20th Jan 2023 7:40am |
Next you’ll be dropping the sump to paper towel the innards sir 🥴🥴🥴 1st sign of madness that is sir |
20th Jan 2023 8:37am |
Ahhhh brilliant… Love that… |
20th Jan 2023 8:38am |
I've been mad for quite a while now Craig. |
20th Jan 2023 9:01am |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 377 |
If only that was easy on these cars... I need to remove the sump on mine to change the oil level sensor and have been told it is a 10-hour job involving dropping the front subframe ... Current: - 2017 L405 3.0 V6 Autobiography Sold: - 2013 L405 4.4 TDV8 Vogue - 2004 L322 4.4 Vogue (BRC LPG) - 2002 L322 4.4 HSE (having fixed timing chain guides) - 2000 P38 4.6 Vogue (BRC LPG) - 1981 2-door In-Vogue - 1980 Ex-Army SIII LWB - 1976 SIII LWB - 1968 SIIA Stripped for parts: - 2003 L322 4.4 Vogue |
20th Jan 2023 9:19am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
that is bad!! why do people spend so much on a car then just do not have them looked after?
20th Jan 2023 9:30am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
Has the short wiring harness from the side of the sump been fitted? If not then fit it first to see if it cures the problem. |
20th Jan 2023 9:38am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
Nice tip Pete, as for first sign of madness CTC, we're all mad, we own FFRR's
20th Jan 2023 10:08am |
The purpose of the short wiring harness is really a temporary fix to prevent oil seeping further into the wiring loom, rather than fix a faulty sensor. See this thread: www.fullfatrr.com/forum/topic56693.html Current: - 2017 L405 3.0 V6 Autobiography Sold: - 2013 L405 4.4 TDV8 Vogue - 2004 L322 4.4 Vogue (BRC LPG) - 2002 L322 4.4 HSE (having fixed timing chain guides) - 2000 P38 4.6 Vogue (BRC LPG) - 1981 2-door In-Vogue - 1980 Ex-Army SIII LWB - 1976 SIII LWB - 1968 SIIA Stripped for parts: - 2003 L322 4.4 Vogue |
20th Jan 2023 11:18am |
Merchy -interested in the cause of the cracks (retired dark side ) was it Engine related ie crankshaft alignment /overload? or Structural -poor welding or poor design lack of adequate stiffening etc. Did it have resin chocks?
20th Jan 2023 11:35am |
