Home > Maintenance & Mods (L405) > Importance of regular servicing!!
kevinp
Just shows that you never know how a car has been treated in the past!!
Post #653965 18th Jan 2023 10:33pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Ewww...
Oil like that is either wrong spec or has not been changed for ages - or both! Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #654028 19th Jan 2023 3:57pm
Kot
Yep every 3 months for me. I guess there a few owners who ignore the app or the dash service notification.
Oil is cheap an Engine etc is not.
Is there a reg number? I would not want to be the next owner Whistle 2018 SE SDV8 4.4 Byron Blue
Post #654038 19th Jan 2023 5:54pm
WOWSERS!!! Not seen one that bad before... Shocked Shocked Shocked
On the up side, he did have rather friendly looking daughters... Whistle Whistle Whistle Thumbs Up
Post #654083 19th Jan 2023 10:57pm
kevinp
My top tip to get as much old oil out as possible is;
I use a syringe and small pipe to suck out the old oil from the hole inside the oil filter housing.
It's surprising how much you can get out. Thumbs Up
Post #654097 20th Jan 2023 3:19am
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Basil, I told you not to use O’Reilly! 2016 SDV8 AB
Post #654104 20th Jan 2023 7:40am
Next you’ll be dropping the sump to paper towel the innards sir 🥴🥴🥴
1st sign of madness that is sir Laughing Laughing Bow down Whistle Thumbs Up
Post #654108 20th Jan 2023 8:37am
Ahhhh brilliant… Love that… Bow down Bow down Bow down Thumbs Up
Post #654109 20th Jan 2023 8:38am
kevinp
I've been mad for quite a while now Craig. Thumbs Up
Post #654113 20th Jan 2023 9:01am
Zebedee
If only that was easy on these cars... I need to remove the sump on mine to change the oil level sensor and have been told it is a 10-hour job involving dropping the front subframe ... Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #654115 20th Jan 2023 9:19am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
that is bad!! why do people spend so much on a car then just do not have them looked after?
i change mine twice a year regardless of milage. been doing that on all cars i own for years. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #654117 20th Jan 2023 9:30am
GraemeS
Has the short wiring harness from the side of the sump been fitted? If not then fit it first to see if it cures the problem.
Post #654118 20th Jan 2023 9:38am
Merchy
Nice tip Pete, as for first sign of madness CTC, we're all mad, we own FFRR's Whistle
As Kot says, oil is cheaper than engines Thumbs Up
The most expensive oil change I have ever been involved with was when a vessel I worked on had to have a new main engine bedplate ( Due to severe cracks found in the main bearing support walls ) ...so....steps taken...pump 40 tonnes of old oil ashore, pay for collection and disposal, after engine rebuild, add approx 22 tons of special flushing oil, heat and circulate this then pump flushing oil shore for disposal etc, then put in approx 40 tonnes of new oil...... Big Cry
Post #654124 20th Jan 2023 10:08am
Zebedee
The purpose of the short wiring harness is really a temporary fix to prevent oil seeping further into the wiring loom, rather than fix a faulty sensor. See this thread:
www.fullfatrr.com/forum/topic56693.html Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #654128 20th Jan 2023 11:18am
Kot
Merchy -interested in the cause of the cracks (retired dark side Rolling with laughter ) was it Engine related ie crankshaft alignment /overload? or Structural -poor welding or poor design lack of adequate stiffening etc. Did it have resin chocks?
Was it a new build?
Sorry for going off topic guys and gals Whistle
Maybe PM the answer Whistle Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #654130 20th Jan 2023 11:35am
