Home > My Range Rover > Back with another Supercharged |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
The SVR is one of my guilty pleasures David… Best of both worlds imho sir… |
7th Jan 2023 1:07am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3131 |
Handbrake fault has been traced tonight, it looks as if it’s a chaffed wire on top of the subframe. That’s probably going to be great fun to resolve!
18th Jan 2023 11:55pm |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
Is there any part you haven't replaced yet mate haha
19th Jan 2023 6:32pm |
There can’t be much, that’s for sure!
19th Jan 2023 7:43pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2269 |
Just keep it and buy an SVR as well easy peasy |
19th Jan 2023 9:26pm |
I’ll let you broach that subject with the wife, Sandy 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
19th Jan 2023 9:32pm |
Ah yes there is always that bit to be negotiated I tend to park them round the back of the outhouse mind you I was asked only the other day "Why are those two old cars in the garden?" I tried to explain that a classic and a p38 were not two old cars then just took her for lunch so might get away with it |
20th Jan 2023 7:11am |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 |
Don’t mention it to her till it’s on the drive.
20th Jan 2023 7:43am |
That is my commonly used go to phrase
20th Jan 2023 9:34pm |
One other issue I’ve had but haven’t mentioned as I’ve got used to it is the car not starting when you crank it first time on the key. It’ll turn and splutter but not actually fire. If you stop it, cycle the ignition and flick the key again it’ll start first time.
20th Jan 2023 9:50pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
David, last time i saw something similar it was on a diesel TDCI 2.0 i think. i traced it back to the fuel filter and the return on it. although it was brand new (Because of this took me a while to look at it) and it was a Delphi one who made the Ford branded ones!! i changed it out and problem solved!!
21st Jan 2023 7:01pm |
I had a look at this very briefly this afternoon.
21st Jan 2023 7:06pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
LPG has a lot of hidden pitfalls - even when it isn't fitted! - that could also be contributing to your O2 issues as the pump would be running at a higher duty cycle, meaning a slightly high fuel pressure on overrun as the pump would have more momentum than if it were running at a lower speed. I think you're right - plugging the outlet is the best & most cost effective option, maybe a slight taper on the turned plug? |
21st Jan 2023 8:44pm |
Cheers Phoenix, glad to know someone else agrees with my line of thought.
21st Jan 2023 9:27pm |
