Home > My Range Rover > Back with another Supercharged
Page 54 of 58 <123 ... 535455 565758>
The SVR is one of my guilty pleasures David… Best of both worlds imho sir… Thumbs Up
Post #652827 7th Jan 2023 1:07am
dhallworth
I've just posted on the RRS forum this afternoon trying to work out what sort of range they get from a tank.
I know it's not the kind of car you buy for economy, but I also don't want to be filling it every 3 days either as that would just drive me nuts.
There's a nice one with 26k miles on it at a dealer in Ayr that I'm almost tempted to go and have a look at. It's a 2016 though and I'd like a 2017 if I'm going to spend that kinda money due to the newer infotainment.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #652830 7th Jan 2023 1:10am
dhallworth
Handbrake fault has been traced tonight, it looks as if it’s a chaffed wire on top of the subframe. That’s probably going to be great fun to resolve!
I’ve also found the cause of the steering from the rear. The toe control arm on the OSR can be moved when grabbing it and shaking. It’s a tiny amount but I can hear it click so I’m going to remove it tomorrow evening and see what’s what. With a bit of luck it just wasn’t torqued properly when the car was tracked.
I found a vacuum pipe that goes from the fuel pressure regulator to the spigot on the plate on top of the supercharger tonight too. I’m going to put a hose clip on it to secure it. I’ve also ordered a MAF sensor and 2 pre-cat oxygen sensors to start with as good a chance as possible to resolve the rich running issue.
Looks like it’s going to be a busy weekend!
Post #653976 18th Jan 2023 11:55pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Is there any part you haven't replaced yet mate haha
Allen
Post #654043 19th Jan 2023 6:32pm
dhallworth
There can’t be much, that’s for sure!
Annoyingly, one of the lower control arm bushes I replaced is knackered. The NS one is perfect but I noticed whilst under the car today that the OS one is torn.
I know I had the car on its wheels at normal height before I torqued the arm up but am now wondering if I got the bush slightly out of alignment when I fitted it.
At least it’s an easy one to sort!
Post #654054 19th Jan 2023 7:43pm
Sandyt
Just keep it and buy an SVR as well easy peasy
Post #654070 19th Jan 2023 9:26pm
dhallworth
I’ll let you broach that subject with the wife, Sandy Laughing 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #654072 19th Jan 2023 9:32pm
Sandyt
Ah yes there is always that bit to be negotiated I tend to park them round the back of the outhouse mind you I was asked only the other day "Why are those two old cars in the garden?" I tried to explain that a classic and a p38 were not two old cars then just took her for lunch so might get away with it Confused
Post #654102 20th Jan 2023 7:11am
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Don’t mention it to her till it’s on the drive.
Remember, it’s Easier to ask for forgiveness than permission.
Post #654105 20th Jan 2023 7:43am
dhallworth
That is my commonly used go to phrase Laughing
Tonight saw the oxygen sensors and air flow meter changed on the Range Rover.
I ordered 2 Denso pre-cat sensors and a Denso MAF from Island 4x4. Total cost inc delivery was £368.96.
To do the oxygen sensors I removed the down pipes from the manifolds to drop them down and give me some more room. I then used the induction heater to warm the sensors and with a 22mm spanner they undid nicely which was a relief as I was expecting them to be horrendous.
New v Old
Don’t have any pictures of swapping out the MAF though.
After these were both done I reset the adaptions and will get some miles on it to have a look and see what’s what from there. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #654193 20th Jan 2023 9:34pm
dhallworth
One other issue I’ve had but haven’t mentioned as I’ve got used to it is the car not starting when you crank it first time on the key. It’ll turn and splutter but not actually fire. If you stop it, cycle the ignition and flick the key again it’ll start first time.
If you put the ignition on, then off again, then on again and crank it then it’ll always start first time without any problems.
Tonight I decided I’d have a look at that on the IID tool too.
This is the fuel pressure that was showing with the ignition on the first time was 4.10kPa which is 0.6psi.
I then turned it to graph mode and cycled the ignition and you can instantly see the pressure shoot up to where it should be.
Interestingly it continues to drop off rather than maintaining a constant pressure. You can clearly see when the ignition was cycled on the graphs.
Once the car is started the pressure is consistently within the pressures outlined in the workshop manual.
I’ve been looking in the workshop manual and the non return valve on this car is part of the fuel pump assembly in the tank. I was going to order a replacement but I had a think about it. There is a solenoid valve that was part of the LPG system. This engine doesn’t have a fuel return line, it’s all controlled from the pressure regulator on the pump assembly in the tank so there’s a T put into the fuel line that runs through a 12v solenoid.
When the car switched to LPG the solenoid opened and kept the fuel pressure at a constant 45PSI. I’m wondering if this solenoid has become a bit leaky and is allowing fuel to pass. I’ll remove the pipe from the outlet tomorrow and check that, if it’s holding pressure properly then it looks like I’m going to need a fuel pump.
Post #654194 20th Jan 2023 9:50pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
David, last time i saw something similar it was on a diesel TDCI 2.0 i think. i traced it back to the fuel filter and the return on it. although it was brand new (Because of this took me a while to look at it) and it was a Delphi one who made the Ford branded ones!! i changed it out and problem solved!!
basically it was siphoning the fuel filter empty when stood overnight, then the car would not start at all. however as these did not self purge if you re-purged it the car was fine for the day or if left a couple of hours you had to do the two turns of the key.
any how some useless waffle for you Shocked Very Happy Laughing 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #654288 21st Jan 2023 7:01pm
dhallworth
I had a look at this very briefly this afternoon.
With a screwdriver to open the flap on the fuel filler, the fuel return that was plumbed in for the LPG is easily visible.
I watched the fuel return as my Dad cycled the ignition. As soon as the ignition came on there was a small spurt of petrol and some bubbles appear. After the car was started there was a small (very small) but constant trickle of fuel out of it.
Obviously the fuel return solenoid that was part of the LPG is allowing fuel to pass. Tomorrow’s job is to remove it and block it totally before refitting. Unfortunately, removing it completely would mean replacing the pipe from the tank to the front or at least part of it.
I’m thinking I might turn a small piece of metal in the lathe and press it into the solenoid feed to totally block it.
The LPG on this car has been a total pain in the backside! Laughing
Post #654291 21st Jan 2023 7:06pm
Phoenix
LPG has a lot of hidden pitfalls - even when it isn't fitted! - that could also be contributing to your O2 issues as the pump would be running at a higher duty cycle, meaning a slightly high fuel pressure on overrun as the pump would have more momentum than if it were running at a lower speed. I think you're right - plugging the outlet is the best & most cost effective option, maybe a slight taper on the turned plug?
Post #654305 21st Jan 2023 8:44pm
dhallworth
Cheers Phoenix, glad to know someone else agrees with my line of thought.
I miss the LPG running costs but don’t miss the lumpy idle that was caused by the worn valve seats.
Once I can get to the bottom of these issues and get it the way I want it I’ll be quite happy.
Post #654308 21st Jan 2023 9:27pm
