Home > Maintenance & Mods (L405) > l405 battery
Page 5 of 8 <12345678>
Kot
supershuttle wrote:
Quick follow up question, the handbook says remove the battery to charge it. That will be a royal ballache or at the very least backache so can I just connect my c-tek to the jump start terminals under the bonnet.
I use the terminals, with the crocodile clips, I should get around to doing a Luxmoggy permanent solution though Thumbs Up 2018 SE SDV8 4.4 Byron Blue
Post #650247 9th Dec 2022 10:07am
Gremlin500
………. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #650256 9th Dec 2022 10:36am
Gremlin500
Post #650257 9th Dec 2022 10:37am
MrWold
England 2014 Range Rover Autobiography SDV8 Barolo Black
Gremlin500 wrote:
That KINGBOLEN BM580 battery tester on AliExpress is super, and for only £26 it’s almost a no-brainer, tells you exactly what’s going on in seconds, without hardly getting your hands dirty, -a “must have” for the tool box.
This probably makes it a complete no-brainer. Just ordered one and cost £18.98. It would have been £14.72 with my first AliExpress order discount but I'd messed up my address so cancelled and reordered. Hint, set up address before checkout even if using paypal. Chris
2014 FFRR 4.4 SDV8 Autobiography Barolo Black
2012 RRS SDV6 HSE Baltic Blue
and before I saw the light:
2011 Suzuki Grand Vitara SZ5
1998 Ford Mondeo V6 Ghia X
1990 Citroen BX GTi
1973 Triumph GT6
Post #650262 9th Dec 2022 10:50am
supershuttle
Gremlin500 wrote:
@Kot
See pic in my gallery…
Very neat Very Happy Geoff
Post #650263 9th Dec 2022 10:52am
Kot
luxmoggy wrote:
So I have disconnected the charger. I am watching the voltage of the main battery via the App. It has a reading of around 12.8v. Which is so much better than the old battery. I will fit the other battery and monitor on Friday. I am happy that I have done this.
So what's the app and the monitor you are using? I have to have it!!!! Big Cry 2018 SE SDV8 4.4 Byron Blue
Post #650266 9th Dec 2022 11:08am
Kot
luxmoggy wrote:
The main battery was replaced today. With the GAP Tool (Beta), the action of the main battery replacement was done.
So you got me thinking, and I used my mate Google, and found a new development with GAP tool for 2017+ cars which I didn't know about so a new thread to start Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #650268 9th Dec 2022 11:31am
supershuttle
Just looked in my C-Tek bag and found the adapter to connect to my 13pin towing socket - you think that's daft I must have bought it from this site but never used it. My memory ain't what it was Embarassed Geoff
Post #650270 9th Dec 2022 11:42am
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
So both new batteries are in the car, and both have a monitor on them. BTW Land Rover only monitors the main battery in my car. Due to the small space and exec seating. So I get the low battery warning when the main battery is low, but the second battery with another 70Ah is still full and ready to go, therefore the car will start.
The terminal under the bonnet reflects the main battery voltage. The values from the monitor and my multimeter are less than .05v different.
I will post photos later showing the monitors in place and their app. The extra Ctek quick connector connected straight to the main battery.
So the tester arrived today. I will play with that later. I also "had" to buy some ratcheting spanners for working on the secondary battery - I am so upset about more tools. Whistle Whistle Laughing
Current Voltage: Main 12.64v and Secondary 12.79v (this is while sitting in the kitchen having a coffee) SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #650285 9th Dec 2022 1:26pm
knwatkins
I also have 2 battery monitors, one on each battery. They are very handy and have been installed for around about 2 years.
What model did you go for luxmoggy? BM2? Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #650289 9th Dec 2022 3:06pm
luxmoggy
So I installed 2 BM2's in the car.
This is the software monitoring the 2 batteries. I will also add a monitor to my Mini.
So I had to monifiy the backet for the second battery
Fitted with the monitor attached. It slips under the fuse panel and won't rattle.
The main battery with the monitor and another CTek quick-fit connector. The monitor I zip-tied to the bracket and the other wires are now cleanly under the carpet.
The CTeck connector hides away. I can lift the floor and connect directly to the main battery and have the charger inside the car.
But I still haven't found any of these. M8 with a 10mm top. If someone knows where I can get them please tell me.
The guys at the garage had no idea - can only follow what the Topix say and not think out side the box and no part number listed.
 SDV8 AB MY 2020
Post #650295 9th Dec 2022 4:11pm
supershuttle
Is it easy to tell if my car has two batteries? Geoff
Post #650391 10th Dec 2022 4:02pm
take the off side rear panel off and you''ll see a battery or not.. ... - .- -.
Post #650392 10th Dec 2022 4:08pm
supershuttle
Is it easy to remove, how do I go about it? Geoff
Post #650419 10th Dec 2022 8:01pm
luxmoggy
it is easy. I just grab the top and pull.
 SDV8 AB MY 2020
Post #650421 10th Dec 2022 8:16pm
