![]() | Home > Maintenance & Mods (L405) > l405 battery |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
The Exides are physically an exact match for the OE batteries for my MY and a very straight swap.
Both 10+ year old original batteries reading 12.7v - but I know I've been on borrowed time.
Thanks to Kev for the battery recommendation & Stan for the window reset procedure |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8530 ![]() ![]() ![]() |
You don't "have to" inform the car it has a new battery... it will work fine without... Just takes a little longer to sort itself out but rest assured it will, certainly don't waste money getting an indie to do it... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Norman.D.Seagull Member Since: 20 Dec 2022 Location: Lymington, Hampshire Posts: 14 ![]() ![]() ![]() |
General question on charging - I have charged cars for years but knowing how sensitive the RR can be and hearing about a second battery (or not) is it Ok to charge on the under bonnet posts or is it best practice to fit directly to the boot battery ? I have stopped doing short journeys as 'low battery' warning came on and also remembering to lock the car also helps prevent battery drain. I use the car every other week so I have a NOCO genius charger for when it is standing.
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 494 ![]() ![]() ![]() |
I have charged from under the bonnet and direct to the main battery. I think it is the same.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
Mine was charged through the towing electrics socket using an adaptor bought from the forum shop (maybe no longer available, but can be got elsewhere) during the Covid lockdown and that worked fine and was convenient with no need to open bonnet etc. Only Range Rovers since 1988 |
CubaLibre Member Since: 12 Jun 2014 Location: Herts Posts: 12 ![]() ![]() |
Thanks for posting pictures of the replacement batteries Alistair which really helped me out. I bought the same ones and replaced them this morning. Very easy job to do and there was no need to reset the BMS. Only thing that needed doing was a reset of the clock and date.
AnnualMan Member Since: 16 Apr 2023 Location: Zurich Posts: 175 ![]() ![]() |
Most likely need to change my auxiliary. Does anyone have any experience as to whether the following is really necessary?
I didn't & they seem to work just fine. |
Me neither |
Superb! Thanks.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1674 ![]() ![]() ![]() |
Yank harder! 💪🏻 “If it ain’t broke, don’t fix it” -where’s the fun in that? |
Pull from the top only. The bottom is in a kind of rail.
