Home > Technical (L322) > Permanent fix for leaking throttle body pipe
Page 1 of 3 123>
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
Like nearly all 4.4 TDV8 owners the rigid plastic connector to the throttle body is leaking, it’s an awful design from the start and most look like this after several thousand miles
The problem is the seal inside really isn’t upto the job and the fit is so loose it’s comical it ever got past the design stage, I’ve been thinking for a while how to solve this issue and I think I’ve done it, this is my connector 2000 miles after the fix
The fix is so simple and costs under £20 and doesn’t involve PTFE tape, to fix this irritating issue you will need the following
Small flat blade screwdriver
7mm socket
3 75mm int diameter 3mm O Rings
To start remove the rubber intercooler pipe using the 7mm socket
Then undo the clamp on the small pipe top right of the connector and remove the pipe
Next in clip the electrical connector bottom left of the pipe
Finally pull out the metal retaining clip and remove the connector
This is what it looks like inside
The seals are usually misshaped and don’t form a great seal, just in front of the seal is a rigid plastic retaining ring to remove this use the small flat bladed screwdriver to pop the retaining lugs inwards like in the picture below
You can put the rigid retaining ring aside, next get the three 75mm O rings and slide them over the metal throttle body then fit the original seal as below
Finally re fit the rigid plastic part, re connect the plug and pipe and re fit the intercooler pipe, after 2000 miles mine is as clean as the day I did the repair
Hope this helps others if you do a search on eBay you will find the o rings 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #650208 8th Dec 2022 9:58pm
GraemeS
Australia
I tried a single 3.125" ID x 5mm in the housing but it was too thick so will try a 3.125" x 1/8" next time.
Post #650210 8th Dec 2022 10:15pm
Furnitureman
Try the fix above it works 2000 miles later no leaks it’s a simple fix 2012 Range Rover Westminster 4.4 TDV8
Post #650226 9th Dec 2022 7:55am
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Looks good! Thumbs Up
The rigid plastic retaining ring that’s popped out. Do you refit that, or leave it out? I suspect it is no longer needed, but want to be sure… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #650230 9th Dec 2022 8:49am
DrRob
Thumbs Up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #650232 9th Dec 2022 9:09am
JayGee
Mine isn’t leaking but will do this mod anyway - many thanks! 2012 TDV8 Vogue (L322)
Post #650234 9th Dec 2022 9:38am
GraemeS
Australia
Mine's not leaking but I'm looking for an appropriate replacement for the seal in the housing. Loose o-rings on the throttle body don't enthuse me.
Post #650235 9th Dec 2022 9:46am
Furnitureman
GraemeS
Thing is there not loose they wedge up against the slope of the throttle body and up against the lip inside the rigid plastic pipe, absolutely no where to go and an air tight seal this is after 2000 test miles,
If you find a better cheaper way please share either way it works and costs under £20 2012 Range Rover Westminster 4.4 TDV8
Post #650287 9th Dec 2022 2:52pm
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Great work. I ended up replacing the hose, the throttle body, the donut hoses and the other pipe with the fragile plastic connector to resolve my intermittent restricted performance. However, when the seal starts to go on the throttle body connector, as it surely will, I’ll do this mod.
Post #650294 9th Dec 2022 5:07pm
garyRR
Just to add that I recommend the gas specification PTFE tape as a diagnostic step or temporary repair only (considering it costs 50p and you can get some in any hardware store), to confirm if the seal is causing a restricted performance problem or hold out until you can obtain a new part, not as a permanent repair.
Incidentally however, my 'temporary' repair has now been in place for thousands of miles. 2015 Range Rover Autobiography 4.4 SDV8
Post #650302 9th Dec 2022 6:02pm
mgrover
love the fix.
ordered the orings.
id recommend doing it early before the leak absolutely wrecks the boost control solenoid just under it and to the right. Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #670978 11th Aug 2023 2:12pm
JayGee
Did mine with 0 rings and PTFE as it was leaking a bit. Pretty sure it's made an improvement to drivability and the harsh 1-2 shift is now not noticable. Cant remember how many rings I used but it took considerable force to get the retaining ring to engage and it then became solidly fixed. 2012 TDV8 Vogue (L322)
Post #670995 11th Aug 2023 5:33pm
Jon G
United Kingdom 2011 Range Rover Vogue 4.4 V8 Baltic Blue
Not leaking yet but Ordered the O Rings and will do this anyway 👍👍 2001, 4.4 TDV8, Vogue, Baltic Blue
Post #670996 11th Aug 2023 5:41pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Me also, ten 75mm x 3mm O rings for £5.50 on eBay, so I’ll have spares.
https://www.ebay.co.uk/itm/143395883454?var=442325233459 Jonathan
2007 Defender 90 XS Hardtop
Post #671001 11th Aug 2023 8:12pm
JCW
Just completed this and now have a movement free joint between the plastic intake and throttle body so assume it’ll be leak free, but I’ll check for any oily mess escaping after a few journeys.
A couple of things from me, I needed four o rings rather than three to get a firm seal, I also found I needed to bend the spring clip into a tighter circle before refitting to get it to ‘spring’ into place in the groove and hold the plastic intake firmly.
I also have 6 o rings left over that I’’m happy to post to someone if they want to try this mod out themselves 👍 Jonathan
Post #671634 21st Aug 2023 11:13am
Page 1 of 3 123>
