Home > Technical (L322) > Permanent fix for leaking throttle body pipe |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2784 |
I can't rememberexactly how it comes off but don't recal this being a particularly difficult procedure so just work it out as you go along. 2012 TDV8 Vogue (L322) |
13th May 2024 5:41pm |
Mfcetin Member Since: 26 Jun 2023 Location: Nuremberg Posts: 50 |
I recently undid it with a thin flat head. Just stick from top but be careful. Use a thin one 2011 Vogue SE 4.4 TDV8 |
13th May 2024 5:54pm |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 186 |
Many thanks for your response both and a good light and small screw driver shd do the trick then.
13th May 2024 10:07pm |
Just did mine again.....
18th May 2024 9:57am |
Many thanks JayGee for the precise description on this job. Its a "restrictive space" for the plug mentioned but your comments have given me confidence to try that plug again. I did put a little silicone spray to it when last looked at it which will help. I'm glad that I didn't try to force it and think you might add an update when you try the new size O rings you ordered out.
18th May 2024 11:36am |
