Home > Technical (L322) > Testing viscous fan
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
Testing viscous fan
I think mine is fubar but if anyone else can do some checks for me I would really appreciate it.
Fan makes a loud clicking noise on start up and has lost its loud howl on start up as well,
If I spin the fan when cold it will not free wheel but is stiff then less stiff then stiff etc
After getting upto temp if I turn off it wi turn but not free wheel and definitely not locked
With AC on it would definitely engage after a while at idle but I’ve not noticed it
If anyone with the 4.4 TDV8 could do the following for me I’d really appreciate it before I order a replacement
.1. Test when cold does it spin freely etc
.2. Test when hot will it turn or is it locked up
Thanks in advance 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #647983 13th Nov 2022 10:40am
Furnitureman
Anyone able to just check there’s for me please 2012 Range Rover Westminster 4.4 TDV8
Post #648077 14th Nov 2022 7:33pm
Furnitureman
anyone 2012 Range Rover Westminster 4.4 TDV8
Post #648338 17th Nov 2022 12:08pm
JayGee
I'll test the fan cold when I get back from work later this afternoon 2012 TDV8 Vogue (L322)
Post #648341 17th Nov 2022 1:35pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
will check over the weekend i can check cold but have to wait to check hot as i need to replce top hose.
however i will say this
AC - does not engage the Viscous unit there is another electric fan for this that comes on when the AC is on. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #648343 17th Nov 2022 2:40pm
JayGee
Doesn't spin free when cold on mine. Definitely feels like it's connected to something with 'drag' 2012 TDV8 Vogue (L322)
Post #648362 17th Nov 2022 6:07pm
Phoenix
Re: Testing viscous fan
Thanks in advance
You are aware that the engine cooling fan is electrically controlled with a variable lockup clutch controlled by a PWM signal, aren't you? the checks above won't really tell you much about the correct operation of it.
ETA:
From Topix
Quote:
For additional airflow through the radiator matrix, particularly when the vehicle is stationary or slow moving,
there is an engine driven electro-viscous unit. This unit functions as a normal viscous fan, but with electronic
control over the level of engagement of the viscous clutch. The Engine Control Module (ECM), which
determines the required fan speed, controls the level of clutch engagement. The ECM determines engagement
based on the coolant, ambient and transmission oil temperatures and Air Conditioning (AC) system pressure.
The fan is mounted using a Left Hand (LH) thread.
The viscous fan unit is electronically controlled by the ECM to optimise fan speed for all operating conditions.
• NOTE: If the electrical connections to the viscous fan are disconnected the fan will 'idle' and overheating may
result. The ECM stores the appropriate fault codes in this case. A 'check engine light' will also be displayed in
the instrument cluster.
Post #648367 17th Nov 2022 6:30pm
JayGee
The fact that it makes a loud clicking sound would be enough for me know something is very wrong without any other tests. 2012 TDV8 Vogue (L322)
Post #648370 17th Nov 2022 6:41pm
Jayk69
i get a ticking sound when i start cold as i understand things this is the VF i always thought it was the Heater thingy trying to fire up. anyhow the clicking stops as the car warms up. 2012 Vogue 4.4 TDV8 - Current
Post #648432 18th Nov 2022 11:59am
Furnitureman
Mine has drag when cold and hot 2012 Range Rover Westminster 4.4 TDV8
Post #648437 18th Nov 2022 12:19pm
Furnitureman
2012 tdv8 doesn't have a separate fan for the AC it got a electric clutch in it for the AC 2012 Range Rover Westminster 4.4 TDV8
Post #648439 18th Nov 2022 12:21pm
JayGee
Mine doesn't tick. It doesn't 'rev up' when started but does when moving off hot or cold. 2012 TDV8 Vogue (L322)
Post #648444 18th Nov 2022 1:33pm
Jayk69
I stand corrected i could have sworn i had a fan on front of the rad pack but alas no it does not, My TD6 defiantly did. appologies for the duff info Mr. Green 2012 Vogue 4.4 TDV8 - Current
Post #648445 18th Nov 2022 1:36pm
Furnitureman
No worries mate i appreciate you taking the time to try to help 2012 Range Rover Westminster 4.4 TDV8
Post #648510 19th Nov 2022 8:09am
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Mine isn't a TDV8 but a 4.2 Supercharged. I also had a problem where the viscous fan made a loud metalic clicking noise when cold, it worked otherwise and cooled the car properly. I bought a new viscous fan as the noise became annoying.
Post #648542 19th Nov 2022 2:11pm
