Home > Technical (L322) > L322 Rear sub frame bush replacement info
Page 2 of 4 <1234>
Davidmudley
Thanks David, I've ordered the lubricant, pretty frighteningly expensive for a tube of lube (if I'm imagining it correctly), best part of £50. Well I'd rather do the job properly than save a few pennies. Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR
Post #647825 10th Nov 2022 1:20pm
kevinp
I've got some David but I have not opened the box yet. Apparently there should be a 100ml bottle inside. Thumbs Up
Post #647832 10th Nov 2022 3:45pm
Merchy
Jesus wept, that is expensive, from my limited knowledge, would I be correct if I thought that something like the below link is the same as the LR product ? This stuff - Red rubber grease - is perfect for use with rubber as in bushes / 'O' rings etc.
https://www.ebay.co.uk/itm/284457657321?ha...R-CVibyMYQ
If this is the same, then people could save a fortune
Post #647866 10th Nov 2022 10:57pm
dhallworth
The Land Rover stuff is a liquid and is a sort of barley colour.
I used a paint brush to paint it onto my bushes when fitting. There’s still most of the 100ml bottle left after I’d done all 4.
The paint brush I used for mine I didn’t bother to clean and left it on my bench. When I picked it up a day or two later all of the bristles fell out of it so there’s something in that bottle that doesn’t agree with paint brushes!
Bottle says irritant on it too so I used gloves when working with it.
Post #647869 10th Nov 2022 11:46pm
kevinp
I paid £31.95 for a bottle. I've read somewhere that you have to leave it to cure for 24 hours.
Post #647871 11th Nov 2022 12:00am
Merchy
Thank you gents, if it's done that to the paint brush and takes 24 hrs to cure, it is definitely not the same, good warning to wear gloves. When I do mine I will buy the LR stuff. Thumbs Up
Post #647876 11th Nov 2022 9:27am
dhallworth
I read somewhere about it needing 24hrs too.
It was either on the bottle or the workshop manual. I can't remember which. Once the bushes were in mine I left it on the bench in the workshop for a couple of days whilst rebuilding it before fitting it to the car.
One of the benefits of doing it whilst it was off the car!
Post #647881 11th Nov 2022 10:54am
Sandyt
I did mine a few years ago with genuine parts and it is still driving like new on 230k Thumbs Up Thumbs Up
Post #647905 11th Nov 2022 5:27pm
kevinp
Interested if yours 'felt' different after replacing them Sandyt?
Mine had a minor MOT advisory that they have just started to perish.
Thanks Kev.
Post #647908 11th Nov 2022 6:09pm
Davidmudley
Mine are the same Kev, mount MOT advisory. I just want to get it done though, but I don’t expect to feel any difference once they’re changed, it drives very nicely at the moment already. Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR
Post #647913 11th Nov 2022 7:32pm
Sandyt
Thanks Kev.
As I was in there replaced all the bushes on the rear and yes made quite a difference
Post #647972 12th Nov 2022 8:22pm
pcourtney
good to know, this is now on my list of things to do as mine need replacing as well Big Cry
I have got the Red Rubber Grease for £12 quid already
Granville Red Rubber Grease Brake Caliper Pistons & Hydraulic Systems 500g
just need to get the 4 x subframe bushes now - Meyle say that MEYLE HD-parts are components with enhanced durability.
Compared to OE they were technically improved by reinforcing inner parts, using higher quality materials or modifiying the rubber-to-metal composition.
so they sound like they are superior bushes to me Smile
Post #647973 12th Nov 2022 8:56pm
Phoenix
Rubber grease is for seals that have to maintain some compliance during their service life, the LR sealant, is well, sealant, not lubricant.
The Meyle bushes are designed for BMW, not LR spec. They may well be 'superior' for BMW applications, having seen both LR & BMW bushes first hand, there are differences. I couldn't begin to quantify which are better suited to each application, however, the LR ones appear to have a >10 year lifespan.
Post #647974 12th Nov 2022 9:31pm
vektory
Austria 2012 Range Rover Vogue TDV8 Sumatra Black
I have done this job today on my TDV8 and would like to add that there are two rivets in the subframe for each bush, which I could not remove. Had to use force on the tool to shear off the rivet.
If anyone is interested in the tool and a 24mm ratchet spanner, shot me a DM, shipping from Vienna. TDV8 4.4 MY2012 Vogue Trim
Post #690691 15th Apr 2024 7:34pm
dhallworth
That’s interesting.
It must only be secured using a rivet on the later cars. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #690695 15th Apr 2024 8:05pm
Page 2 of 4 <1234>
