![]() | Home > Technical (L322) > L322 Rear sub frame bush replacement info |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 ![]() ![]() ![]() |
Last weekend, I decided to crack on and replace my rear sub frame bushes on my 2008 TDV8. They've been an advisory on my MOT for a couple of years and they tyre place recently refused to adjust my rear tracking as they felt there was too much movement in the rear sub frame.
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
Brilliant write up |
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 150 ![]() ![]() ![]() |
Thank you. Hope it helps.
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 395 ![]() ![]() ![]() |
Excellent - Need to do mine so PM sent regarding the tool |
Tool is Satra S-XRB16 but if you just search for ‘BMW E53 rear sub frame tool’ on eBay you’ll find them.
Swipe Member Since: 31 Aug 2018 Location: Rustington, West Sussex Posts: 101 ![]() ![]() ![]() |
Good write up, this is one job of a long list that I wanna do for my RR. 2004 Autobiography TD6 Java Black |
My tool is now sold to rjff. Many thanks Richard.
I've just found the tool on the manufacturers website for those who need one -
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
Did the recipient of the tool get round to using it and need to pass it on... ?
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3192 ![]() ![]() ![]() |
I bought one of those tools for 60 quid off eBay. It was utter |
My MoT test advisory was to get them done and it failed on rear brake pipes so I decided to do them both at the same time.
Davidmudley Member Since: 27 Dec 2021 Location: Surrey Posts: 80 ![]() ![]() |
Great write up, I’ll be tackling this soon with LR bushes (2 x rear subframe) and the tool. Which lube should be used prior to fitting the new bushes? Am I right in thinking it should be silicone based synthetic waterproof grease type rather than petroleum based or does it not make a difference? Thanks Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR |
Land Rover sell their own lubricant for doing the job. I'm not sure what it is as it's all Land Rover branded. The part number is LR012582. They call it a sealant.
