Home > Technical (L322) > L322 Rear sub frame bush replacement info |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1199 |
I've got some David but I have not opened the box yet. Apparently there should be a 100ml bottle inside. |
10th Nov 2022 3:45pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1173 |
Jesus wept, that is expensive, from my limited knowledge, would I be correct if I thought that something like the below link is the same as the LR product ? This stuff - Red rubber grease - is perfect for use with rubber as in bushes / 'O' rings etc.
10th Nov 2022 10:57pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3058 |
The Land Rover stuff is a liquid and is a sort of barley colour.
10th Nov 2022 11:46pm |
I paid £31.95 for a bottle. I've read somewhere that you have to leave it to cure for 24 hours. |
11th Nov 2022 12:00am |
Thank you gents, if it's done that to the paint brush and takes 24 hrs to cure, it is definitely not the same, good warning to wear gloves. When I do mine I will buy the LR stuff. |
11th Nov 2022 9:27am |
I read somewhere about it needing 24hrs too.
11th Nov 2022 10:54am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2254 |
I did mine a few years ago with genuine parts and it is still driving like new on 230k |
11th Nov 2022 5:27pm |
Interested if yours 'felt' different after replacing them Sandyt?
11th Nov 2022 6:09pm |
Davidmudley Member Since: 26 Dec 2021 Location: Surrey Posts: 80 |
Mine are the same Kev, mount MOT advisory. I just want to get it done though, but I don’t expect to feel any difference once they’re changed, it drives very nicely at the moment already. Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR |
11th Nov 2022 7:32pm |
As I was in there replaced all the bushes on the rear and yes made quite a difference |
12th Nov 2022 8:22pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 800 |
good to know, this is now on my list of things to do as mine need replacing as well
12th Nov 2022 8:56pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Rubber grease is for seals that have to maintain some compliance during their service life, the LR sealant, is well, sealant, not lubricant.
12th Nov 2022 9:31pm |
vektory Member Since: 27 Feb 2023 Location: Vienna Posts: 21 |
I have done this job today on my TDV8 and would like to add that there are two rivets in the subframe for each bush, which I could not remove. Had to use force on the tool to shear off the rivet.
15th Apr 2024 7:34pm |
That’s interesting.
15th Apr 2024 8:05pm |
