![]() | Home > Technical (L322) > P040D-00 (2F) EGR temperature sensor replacement |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
Yea, especially steering wheel |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1271 ![]() ![]() ![]() |
Is it possible to slide a thicker tube over your home made spanner, and cut a gap in it to reinforce your spanner, or is there no room for anything thicker? |
Well, lets see. Maybe at first I try to find just stronger 13mm spanner with acceptible lenght and cut it as previous.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
It's very satisfying to clear the codes after all the injuries to your hands. And you're the first left-hooker (LHD) to do it. Or you can claim that at least! Well done Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Hi GDDR and others.
All wrong. Finally I found what this sensor doing. All is very simple.
great research!
Jon G Member Since: 02 Dec 2016 Location: Leicester Posts: 120 ![]() ![]() ![]() |
Just want to say a big Thank You to GGDR for this write up.
Just to underdtand what exactly we fixing by changing this sensor:
You're very welcome. and welcome to the club. ![]() ![]() - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Gowsh Member Since: 22 Jul 2022 Location: Notts Posts: 5 ![]() ![]() ![]() |
Hi everyone and thanks GGDR for all the time that you've spent on this and to everyone who has contributed to this epic thread.
Well, we dont know exactly what those temp. sensors doing in addition to bypass valve. Maybe those control also EGR valve itself. We also dont know how system works when some of the value is missing, but probably there is some "basic" program for EGR operation in this case, not exactly according to real conditions.
Mjak42 Member Since: 11 Mar 2021 Location: Warragul, Victoria Posts: 15 ![]() ![]() ![]() |
Here in Australia we don’t have a DPF so we can’t figure out what if anything the sensor does and as I don’t have a DPF, is there a need to replace it and should I just keep ignoring fault, have no engine light or anything on dash, by the way Great instructions on how to change sensor, 2011 Voque 4.4 TDV8 |
1. This sensor not related to DPF at all.
