Home > Technical (L322) > Icarsoft DPF regeneration |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1477 |
Just an obvious note that it's only to be completed once the cause of the DPF filling is resolved.
1st Oct 2022 8:57pm |
JoshVogue94 Member Since: 18 Aug 2022 Location: RCT Posts: 55 |
Yes mate there was a split in one of the intake pipes which I've replaced. I've tried taking it on a run but it won't regen as it's showing a soot level of 33 on the live data. |
1st Oct 2022 9:37pm |
jordon0 Member Since: 06 Mar 2016 Location: derbys Posts: 53 |
i have managed to do regens with an i carsoft
2nd Oct 2022 7:38am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3249 |
Also make sure there are no other engine related fault codes as this can prevent regeneration. This is from the workshop manual
2nd Oct 2022 12:28pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
The very common PO40D-00-(2F) EGR fault code definitely doesn’t prevent Forced Regens with the Gap iid.
2nd Oct 2022 12:51pm |
Still no luck today with the regen. Wondering if I need to tell the car the dpf has been replaced before it will allow the regeneration because of the red warning light? |
2nd Oct 2022 5:36pm |
DO NOT do this. It resets the estimated ash load and the whole regen process will be messed up. 2012 TDV8 Vogue (L322) |
2nd Oct 2022 5:39pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
make sure you have over 1/4 tank of fuel too.
3rd Oct 2022 4:14pm |
https://www.jaginfo.org/threads/icarsoft-forced-dpf-regen.109748/ 2012 Vogue 4.4 TDV8 - Current
3rd Oct 2022 4:18pm |
Tried again today, updated the icarsoft and still no luck had communication failed coming up when trying to do the regen. Wondering if I put a cleaner through the dpf will it get the soot content down enough for me to clear the codes and get the dpf triangle from red to yellow so that I can take it on a run to regen |
6th Oct 2022 5:03pm |
You should seriously consider buying a Gap iid.
6th Oct 2022 7:21pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
What Mike said Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
7th Oct 2022 1:20am |
i carsoft can clear red dpf and force regen as i pointed out 6 month before gap decided to allow people to do this it can be done just seems lile there is some issue
7th Oct 2022 2:21am |
Hi guys bit of an update...
13th Oct 2022 10:08pm |
