Home > Technical (L322) > Icarsoft DPF regeneration
JayGee
Soot load is calculated from differential pressure across the DPF and estimated ash load. It’s all estimated really and any excessive pressure differential should be properly investigated and not just be assumed to be soot load that needs a forced regen. It can be something else like a partially melted pre cat or very excessive ash load. 2012 TDV8 Vogue (L322)
Post #645560 14th Oct 2022 8:12am
JoshVogue94
Wales 2011 Range Rover Vogue 4.4 V8 Santorini Black
Hi mate it was a split in one of the intake pipes that has caused the build up of soot
Post #645561 14th Oct 2022 8:43am
JoshVogue94
Just an update, have given up on the icarsoft and bought the GAP IID. Forced regenerated the car and then cleared the codes and all back to normal with the red dpf full warning gone. Took the soot content from 33.4g to 0.6g. Wish I'd just bought the IID tool at the start instead of wasting money on the icarsoft.
Post #646440 24th Oct 2022 9:23pm
DrRob
Ditto. I bought an icarsoft being a tight northerner and then realised its Censored compared to the IID. IID now in glovebox permanently Rolling with laughter
Buy cheap. Buy twice Rolling Eyes Whistle Laughing Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #646450 25th Oct 2022 7:13am
hotpotatojr
Can anyone list the things which will stop IID from doing a forced regen please?
Im at 31.4g due to an air leak which is now fixed but the forced regen isn't bringing it down.
More than 1/4 tank fuel, only error is P2463-00 dpf pressure sensor B circuit range/performance but I assume this won't clear until the pressure differential is at an acceptable rate?
Thanks
Chris
Post #649659 1st Dec 2022 10:07pm
Gremlin500
Which versions of the iCarSoft are we talking about above? 1, 2, or 3?
I think it might make a difference….. Whistle “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #649662 1st Dec 2022 10:48pm
Phoenix
That DTC will prevent a regen (correlation error) not be set due to one being required. Check the differential pressure with ign. on, engine off - should be pretty close to 0kpa, anything else can point to blocked pipes, condensate in the sensor or a faulty sensor, all of which are 'Tom Jones' problems.
Post #649663 1st Dec 2022 11:06pm
hotpotatojr
Hi, just checked and the "Particulate filter differential pressure - measured" is reading N/A whether the engine is running, or just ignition on. Am I looking at the correct live value?
Cheers
Post #649697 2nd Dec 2022 1:51pm
ddcotbg
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
jordon0 wrote:
i carsoft can clear red dpf and force regen as i pointed out 6 month before gap decided to allow people to do this it can be done just seems lile there is some issue
the iid is all singing and dancing but also a chunk of money in the fact that mine sits in glove box just waiting to be used
This sounds promising. I just got an iCarsoft v2.0 and have the red triangle - wondering how to clear it. Do you go through the options to select 'force regen', then take it on a drive in limp home mode to clear it, or do you do it while it is standing on the drive, just keeping the revs up? Will it clear in limp mode? Ta
Post #652321 2nd Jan 2023 2:26pm
JayGee
Cheers
Only the voltage shows as a live value. Use the Workshop manual downloadable from the Wiki to tell you what the voltages mean 2012 TDV8 Vogue (L322)
Post #652322 2nd Jan 2023 2:48pm
ddcotbg
Post #652327 2nd Jan 2023 3:15pm
jordon0
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
hi you must be driving to force regen, the carsoft will tell you what you should be doing to get it going been a long time since needed to do it
but i seem to recall speed only needs to be above about 25mph which is easily done as opposed to 50mph
Post #652332 2nd Jan 2023 3:56pm
ddcotbg
Nice one. That's really helpful. Will limp it onto the motorway later and give it a go. Thanks again.
Post #652336 2nd Jan 2023 4:13pm
Range Rover L322
Good luck - interested to know how you get on - please update us on here?
. 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #652341 2nd Jan 2023 4:58pm
